Did your Harman Kardon amplifier die during the summer??
Old Jul 8, 2016 | 06:01 PM
JimmyChooToo's Avatar
JimmyChooToo
I just replaced the HK amp in my 2010 R57 Base Convertible with a 21/10 build date with one from a 2015 R60 Countryman with a 16/15 build date. Buy the newest one you can afford, because I think these all will eventually burn out due to heat. My original one lasted 6 years and 69,000 miles which sounds about right. I bet BMW builds these to last at least past the warranty period. The HK amps are rated higher than the Hi-Fi (both are inter-changeable), but has a weaker more cosmetic heat sink. I bet for those two reasons, the Hi-Fi amp has a much lower failure rate than HK.
The other thing about these amps is that they are basically continuously on, because they also power the warning gong sound. This also probably negatively affects their longevity and that also makes these amp failures a safety issue.
I think it would be beneficial to add a CPU fan to these amps and on hot days when the car is parked outside to send A/C to the amp first (on my convertible and in the countryman the amp is under the driver seat) before turning the stereo on. I think that may prolong the life of these expensive amps.
Old Mar 9, 2017 | 01:12 PM
TheJuice's Avatar
TheJuice
I know this is an old thread but can you replace the HK Amplifier with a different version like you did (a newer version from a R60)? I have a Model HS 9598, D-Muster 9239601 AI:01 that just died yesterday. I thought that the D-Muster number needed to match in order to work properly?
My car is a 2011 R56 MCS
-Jason
Old Apr 12, 2024 | 04:48 PM
Billius's Avatar
Billius
I know this is an old thread on top of a really old thread....
My son has just taken over my 2011 R57 Mini Cooper S Convertible. (USA - Left Hand Drive). I have HK tweeters on the A-pillars - so I assume this is the HK audio system with external HK amp...
Had a couple of intermittent audio issues - but never anything that a turn off / on didn't fix..
Until now.... Now - no audio - including any warning chimes etc. The front head unit and radio controls all seem to be working - just NO audio.
So questions please:
  1. There seems to be multiple fuses which could be associated with radio/amp/head unit - F5, F45, F49 - is there any possibility that there is a fuse for the AMP which could have gone - I haven't read this on any google searches - but I wanted to ask you all.
  2. I am going to try and connect an OBD reader - will I be able to see any codes if the amplifier is not working?
  3. I see some kind of plastic cover under the driver (left hand side) seat - I assume the HK amp will be under this cover? [it seems the amps are at other locations on other mini cooper models]
  4. Will I need to remove front seat to get to amp? If so - do I have to remove battery connection to stop alert/or problem with airbag sensor?
  5. Could I at least get to wiring plug without removing seat ? - if so I will try to unplug and plug in again to see if it helps fix?
  6. Any good way to confirm Amp is the root cause?
  7. If I do need to replace amp - I saw advice on getting the newest HK amp possible - what HK amps would be guaranteed to be plug and play?
  8. I read that amps are designed and matched to cope with particular speaker config / specs - so if I get a new amp - will the 'tuning' be correct?
  9. If I want to buy another alternative amp - what ones do people recommend for the my setup please.
Many thanks for reading and any answers - even if partial.
Old Apr 16, 2024 | 06:57 AM
JAMADOR's Avatar
JAMADOR
Following, as I believe my [yet to be picked up] R57 has a suspected dead amp.
Old Apr 30, 2024 | 08:37 PM
Billius's Avatar
Billius
Just tried the replacement HK Amp that I got on eBay for $285
No audio. Same as old one.
This time I checked the plug from the car (unplugged from the amp) there is a couple of pins on the plug with 7V and a couple with 13V.
So there is power on the plug
I was really hoping there wouldn't be so it would point to fuse - even though i checked a bunch of radio related fuses and they seemed ok...
So now what?
Logically it seems the most likely is that this is another dead amp....
Ideally if I had a known good HS9599 I could use that to test .....
​​​​​​My only other idea is some way to test the amp outside the car... But I'm not sure how practical that is? I can use the little cut plug that came with it to feed it 12V (if I can work out pins) but what pins to check output? Would there be any output without the MOS bus audio or whatever input?
Or, send back to eBay and try again?
Old May 7, 2024 | 10:38 AM
DogfaceSGM's Avatar
DogfaceSGM
Not sure if it is good or not but my parts car (2013 R59 Roadster JCW) has the HK system. If I can find where the amp is mounted, if you want it $50 + shipping. If it doesn't work, keep the $50 pay for shipping.
Thinker2112
16
Aug 18, 2022 07:21 AM
ToplessMCRed
Electrical
Jan 12, 2014 08:09 PM
Klwnkar
16
Oct 6, 2010 02:18 PM
tutono
Electrical
Apr 29, 2010 11:03 AM
3 Pack
May 16, 2008 03:27 PM
