FS:: 2006 Mini Cooper S - One owner
Old Jul 4, 2016 | 07:02 AM
abarks's Avatar
abarks
Year: 2006
Model: Coupe
Price: $7800
Mileage: 73000
Color: Chili Red
Location (Region): SouthEast
2006 Mini Cooper S
6-speed manual with factory limited-slip differential (a rare option)
One owner
73,000 miles
No accidents
Fanatically maintained
I bought this car in April 2006. It has been loads of fun, but it’s been 10 years. I’m ready for a new toy. This car has been very well maintained. The common failure points and wear items have been addressed, including:
  • New Bilstein shocks (the expensive yellow ones) installed 2000 miles ago with new mounts.
  • New control arm bushings (PowerFlex urethane), front sway bar bushings, inner and outer ball joints, and tie rod ends
  • New power steering reservoir hoses (original ones leak after 10 years)
  • Crankshaft pulley replaced with one-piece fluid filled pulley (the factory ones break in two)
  • Belt, belt tensioner and damper replaced
  • Crank position sensor o-ring replaced (common cause of oil leaks)
  • Thermostat housing and gasket replaced
  • New upper motor mount
  • Redline fluid in the gearbox
I just performed routine maintenance to ensure that new owner is ready to hit the road
  • Oil change
  • New spark plugs
  • New front brake rotors
This car has an Alta 15% supercharger pulley for more boost and extra power. (I install cooler plugs, NGK BKR-7s to reduce the risk of pre-detonation.)
The paint is in good shape overall. There are some chips on the front of the hood. There’s a scratch on the tailgate that I have touched up.
The tires are mid-life. The car passed state inspection in May, but will likely need tires before next year. The current tires are NOT run-flat.
The factory owner’s manual is in the glovebox. I have the original window sticker. I have a Haynes service manual. All of this is included.
The options on the car are:
  • Red interior accents (only available on red and blue cars)
  • Auto-climate control
  • Limited-slip differential
Attached Thumbnails 2006 Mini Cooper S - One owner-img_20160626_192021.jpg   2006 Mini Cooper S - One owner-img_20160626_192106.jpg   2006 Mini Cooper S - One owner-img_20160626_192148.jpg   2006 Mini Cooper S - One owner-img_20160626_192205.jpg   2006 Mini Cooper S - One owner-img_20160626_192354.jpg
Old Jul 8, 2016 | 07:39 AM
MiniCJCW's Avatar
MiniCJCW
What state are you located?
Old Jul 13, 2016 | 11:26 AM
MiniCJCW's Avatar
MiniCJCW
Is car still available or for sale and what state are you located?
Old Jul 18, 2016 | 02:39 PM
playdough's Avatar
playdough
Hello, is this still for sale?
Ygritte
Jan 22, 2019 06:48 PM
jcrane82
Apr 16, 2016 07:45 PM
cjsdad
R60/R61 Stock Problems/Issues
Mar 19, 2016 10:10 PM
quickcoop
Mar 19, 2016 12:41 PM
automan21
Mar 13, 2016 11:03 AM
