Michelin Pilot Super Sport on Track
Old Jun 23, 2016 | 05:19 AM
omega75's Avatar
omega75
Hi Guys
Did anyone of you actually track his/her MPSS?
I suspect, they're one of the greatest Road Tires but won't last much punishing
on track.
Not sure if i want to drive Sport Cup 2 on a daily basis...
I'quite happy about their performance, even in the rain, but why not aim higher?
Right now, i drive Federal 595 RS-R 215/40 R17 Road and Track...
... With a Quaife ATB and Eiback PRo Kit / JCW Dampers & rear Sway Bar
Cheers Harry
Old Jun 23, 2016 | 05:21 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
they are not even the same class as a 200 tread wear autocross tire like the RE71R, let alone a race tire
Old Jun 23, 2016 | 05:23 AM
omega75's Avatar
omega75
I'd go for the RE71R, but they are not allowed in Switzerland :-/
But - have you driven the MPSS?
Old Jun 23, 2016 | 05:24 AM
Qik420's Avatar
Qik420
I didn't take them on a track, but I did have them on The Dragon and that's kind of the same thing ;-P and they're a fantastic tire. SUPER grippy, you won't be disappointed. A racing tire will be better for a track of course, but the SS's will do just fine.
Old Jun 23, 2016 | 05:30 AM
omega75's Avatar
omega75
OK, thanks!
Old Jun 23, 2016 | 06:02 AM
MrBlah's Avatar
MrBlah
no, they are not competitive at all in autocross
Old Jun 23, 2016 | 09:49 AM
Alex@tirerack's Avatar
Alex@tirerack
Depending on your alignment and driving style. Factory alignment had lead to blistering and uneven tread wear. This is exacerbated further by sliding or over driving.
You may be better off with tires like the Hankook RS-3 or better yet the Yokohama AD-08R for street tires with more track readiness. Both are E-code rated.
Old Jun 23, 2016 | 10:25 AM
RB-MINI's Avatar
RB-MINI
I had PSS's on the track at the last MINI Thunder. Here's of pic of the LR after one of the sessions.
Old Jun 23, 2016 | 10:48 AM
Qik420's Avatar
Qik420
Nice Told ya they are grippy. I've seen full on race tires look worse than that after a practice session as well, same goes for AD08's accept instead of the outside edge, you get that kinda all over the tire.
Old Jun 23, 2016 | 10:02 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I have multiple track days on my 215x45-17 PSS, they do a great job. Not as good as a dedicated track tire obviously but really amazing for a tire that you can also use as a daily driver, which I do. They need to warm up a bit to get the full grip (like any tire), so take it easy for the first lap. I have found that all the ugly looking stuff on the tires after a track day that makes it look like your tires melted is rubber picked up from the track, it wears off after a few days.
Ideally I'd have a set of track wheels/tires, but until I have the $ for that I have to get along with just one set of tires and the MPSS is a fine choice. I am lowered a bit on Ohlins and set up for -2 deg camber all around, I rotate the tires about every 5000 miles and don't have any issue with uneven wear. They are absolutely great on the road dry or wet. My set is almost worn out, about to get another.
Old Jun 24, 2016 | 12:22 PM
Dr. Spade's Avatar
Dr. Spade
Having been to the Dragon and Homestead speedway I can say they are not the same thing.
I took regular Federal 595's to the dragon (205/45-17) and they were not quite enough for Dragon
I've been on the good Federals, 595 RSR for several autocrosses and they nearly hung with the 200TW tires 2 years ago. They haven't had any changes to my knowledge so the new 200TW leaders (Bridgestone RE71 and BFG Rival S) would likely put it to shame.
That said, I actually bought a used set of Michelin PSS with the intention of taking them to Sebring track. The most common complaint I've seen on Federal 595 RSR is they overheat quickly. Most common complaint on PSS seems to be they chunk with a bit of overdriving. This would lead me to believe I need more camber before the track day.
Most important thing that the PSS may have over other Max performance summer tire is the sidewall strength of an extreme performance tire.
Old Jun 26, 2016 | 01:40 PM
omega75's Avatar
omega75
I'm driving with 1° camber and i managed to make my Federals look like that
which seems ok after a track day. i lost about 2mm
I'd say sidewall strength on federals is enormous, don't you agree?
But i think i really wanna try the PSS. Just out of curiosity.
Old Jun 26, 2016 | 01:47 PM
omega75's Avatar
omega75
this was the track i've been:
first track day, no Quaife then and ESP on.
the tires got quite cheesy after 5 or 6 spirited laps.
Interesting hovever, this year, same track, 4 sec faster, the tires looked different, the excess rubber got scrubbed off because of the Quaife maybe or in the rain later that day.
Old Jun 27, 2016 | 05:56 AM
Dr. Spade's Avatar
Dr. Spade
IMG]https://cimg4.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/640x480/80-michelin_pss_track_2b3434a9b4f91858dc9f0119e410ccf 651f4846d.jpg[/IMG]
I'd like to see the front. For a rear that doesn't look so promising.
Old Jun 27, 2016 | 05:57 AM
Dr. Spade's Avatar
Dr. Spade
url="https://youtu.be/FJc_XI0UAy8"]Anneau du Rhin Mini Cooper S - YouTube[/url]
url="https://youtu.be/Y1K0lURE1lk"]Anneau du Rhin Trackday 8.6.2016 MINI Cooper S - YouTube[/url]
url="https://youtu.be/Odw31RlTn4M"]Anneau du Rhin 8.6.2016 Trackday - YouTube[/url]
Looks like they just want more camber. See how much more the outside is worn than inside?
I highly doubt the PSS would keep up with RSRs.
Old Jun 27, 2016 | 06:56 AM
Qik420's Avatar
Qik420
[QUOTE=Dr. Spade;4220103]Having been to the Dragon and Homestead speedway I can say they are not the same thing
I know they're not the same thing. notice the winking smiley face with the tongue out.
Old Jun 29, 2016 | 12:04 PM
omega75's Avatar
omega75
the wear on the inside is an optical illusion, i measured pretty much the same depth, but the scrub is off on the inner half.
i think having more connected blocks or almost solid surfaces helps a lot in terms of wearing...?
Old Jul 14, 2016 | 06:14 AM
Dr. Spade's Avatar
Dr. Spade
Usually does in terms of chunking. I had a bit of a chunking problem when running Toyo R1R's. I expect it would be even more of an issue with PSS.
Old Jul 14, 2016 | 12:54 PM
hsautocrosser's Avatar
hsautocrosser
I will add that is picked up when your tires are hot and you are slowing down to exit the track. Scares many a first-time r-comp or race tire autocrosser venturing out in hot weather later in the day. F1 drivers used to drive in the marbles on their cool down lap to help make minimum post-race weight.
Old Jul 14, 2016 | 05:33 PM
Eddie07S's Avatar
Eddie07S
Also scary the first time that stuff comes off during your first hot lap of your next session, smacks the side of your car and your tire goes out of balance
A lap later all is better.
I have seen that on my ZIIs, RE71Rs and R888s. A tire shop I go to gets really impressed when they see that stuff. They think it is really neat that I melted the tires.
Old Jul 14, 2016 | 05:50 PM
Eddie07S's Avatar
Eddie07S
Tires tend to wear better with less tread.
Nice track video and nice looking "MINI" you were on.
Can you get any 200 wear rated tires like the Dunlop ZII Star Spec tires?
Old Jul 18, 2016 | 07:26 AM
Dr. Spade's Avatar
Dr. Spade
True. The R1R's wore better when shaved; supposedly didn't chunk.
Old Mar 23, 2017 | 12:38 PM
omega75's Avatar
omega75
Hi guys
I recently got the PSS and i love them. Besides Grip in the Dry, they're impressive in the wet.
Compared to the Feder 595 RS-R, they're a fair amount less stiff in the sidewalls, wich makes the initial turn-in kinda less agressive.
But anyways, it has so much more capabilities in terms of adapting to uneven pavement.
All in all, an excellent choice for the sporty daily driver.
What pressure do you guys use on them? So far, i found 34-35PSI quite good (2.4Bar)
Cheers Harry
Chino_0
Oct 9, 2016 04:56 PM
N2MINI
Apr 6, 2016 06:23 PM
HaveATank
21
Apr 3, 2016 07:15 PM
MiniVoid
Apr 2, 2016 05:44 PM
Yam the Bomb
Mar 26, 2016 09:58 AM
