R50/53 Cam Position Sensor O-Ring Size
Old Jun 4, 2016 | 08:54 PM
Filmy's Avatar
Filmy
Apparently I have a slight oil leak at my CPS. I know the crank pos sensor has a replaceable O-ring (I've done it) but is there a simple O-ring for the cam sensor? Looks easy enough to get to the sensor, but at +$70 to replace the whole thing, I'm hoping someone knows if replacing just the O-ring is feasible.
Old Jun 5, 2016 | 11:15 AM
RogueMini's Avatar
RogueMini
Hey Filmy!
The o-rings are cheap:
https://www.ecstuning.com/Mini-2005-...ors/ES2702892/
Getting to the cps is a different story, you have to move the radiator to do the job right:
Clean the area around the cps (it will be very dirty)
Remove the cps
Remove the old o-ring without scrathing the groove it sits in (use something plastic or wooden to pick it out) if you scratch the groove, it will leak.
Clean the cps and the hole in the block so clean you could eat off it
Carefully put the new o-ring on the cps. Any scratch or nick or dirt on the o-ring will cause a leak.
Wipe some clean motor oil on the o-ring so it slides easily into block, and reinstall the cps
Put the car back together, and you're good to go!
Old Jun 5, 2016 | 11:18 AM
Filmy's Avatar
Filmy
I need the camshaft position sensor O-ring. Which resides behind the passenger-side upper engine mount.
ETA: found the single part O-ring via RealOEM:
12147514984
O-ring
Looks like it's available everywhere, typical $3 part. Thanks again Rogue.
Old Jun 5, 2016 | 12:59 PM
RogueMini's Avatar
RogueMini
Oh. Oops.
Never mind.
otfox
Nov 26, 2018 01:08 PM
pfcmooney
Apr 26, 2016 05:01 AM
clubgitmo
Apr 25, 2016 10:24 AM
lasher10
Apr 23, 2016 12:41 PM
htravolta
Apr 21, 2016 08:19 PM
