R50/53 How to remove interior door arm rest trim on 2002 Mini Cooper
Old Jun 4, 2016 | 07:01 PM
Colin Schlagel's Avatar
Colin Schlagel
Ok so I have done a ton of looking up and cannot find anything! I want to take off the grey/silver door trim arm rest on the 2002 mini and I cannot figure out how to get it apart so I can repaint it.
I have the entire interior of the door trim off but I just can't figure out how to get that arm rest with the little leather pad.
Remember that this is the 2002 cause I have found stuff for later models but not the 02
Thanks for the help
Old Jun 4, 2016 | 08:40 PM
Filmy's Avatar
Filmy
Here's a DIY for taking the door off - http://www.minimania.com/MINI_Cooper_Door_Panel_Removal - but it sounds like you've already got it all off. If you're trying to get the large oval out of the panel, or the Y-shaped armrest out of the oval, pretty much everything is molded or plastic-welded in together. You may have to just mask off the oval and paint the Y while it's all in one piece.
Old Jun 5, 2016 | 07:25 AM
RudeJoe's Avatar
RudeJoe
We're trying to do the same thing and it looks like that part does not come off unless you drill out the plastic welds. I've not found any instruction on removing and then reinstalling them. We were going to go the route of masking and painting in place. Painting the back side isn't going to be possible though.
To bad they didn't give this part a better finish since it is a high touch area.
I have seen some leather wraps for this area but they are expensive.
Old Jun 5, 2016 | 08:07 AM
xsmini's Avatar
xsmini
Yep, have to drill out the plastic welds.
How to remove interior door arm rest trim on 2002 Mini Cooper-image-402082152.jpg
Kind of a pain, but worth it.
Nik
Old Jun 5, 2016 | 09:03 AM
RudeJoe's Avatar
RudeJoe
How do you re-attach? Do the posts become screw bosses to fasten back together with screws? If so, what size screw?
Once disassembled is it evident how the armrest cushions come off? From groping around it seems they might be connected with screws at the bottom?
Old Jun 5, 2016 | 09:33 AM
xsmini's Avatar
xsmini
I used a hot glue gun to "weld" it back together. There really isn't enough room for screws of any length.
If I remember correctly there are two small Philips screws holding the cushion on.
Nik
Old Oct 13, 2018 | 11:22 PM
jk6672's Avatar
jk6672
Nik
I know this is an old post, but how is the hot glue working out? I've been wanting to paint mine, but I didn't want to destroy the panel by not being able to put it back together. I've thought about using some slow cure epoxy to reattach it if I go through with my idea.
Old Oct 17, 2018 | 09:02 AM
xsmini's Avatar
xsmini
Overall its been working pretty good, I've only had a couple spots pop apart that I had to re-glue. An epoxy would probably be a bit better.
Nik
Old Aug 16, 2022 | 10:31 PM
John Jordan's Avatar
John Jordan
I know this is older but wanted to share my findings. I have a 2002 as well and there isn’t a clip to remove the pad. There are actually three T-8 torx screws on the back. You will need a Naro Driver to get at them with the panel assembled.
Old Aug 17, 2022 | 07:22 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Good one!
I wonder how many door arm rests have been inadvertently destroyed without having this knowledge.
Thanks!
Old Aug 17, 2022 | 07:48 AM
MCS4FUN's Avatar
MCS4FUN
Agreed, good info! I thought all those trim pieces were secured to the door card by heat-staked pins in the same way as speaker grilles. Door card P/Ns changed with FL models, notably armrest style. Unsure if the trim retention method was also part of that change. I still have my original driver side door card (replaced by very spendy NOS) which had an unsightly dimple-dent but with pristine trim. If I can remove those with a torx driver as suggested, I'll do so and toss the card.
Old Aug 17, 2022 | 08:06 AM
John Jordan
I agree, I almost did by fishing around underneath the pad looking for the clip.
I also removed my speaker grilles for painting and masked the rest of the card to paint the "Y" trim.
Old Aug 17, 2022 | 08:14 AM
MCS4FUN's Avatar
MCS4FUN
OK, I get it now. The suggested method and tools only removes the armrest pad - not the primary trim pieces. On FL door cards, the padded armrest slides and clicks into position from the front side with no attachment hardware on the back side to remove...
Old Aug 17, 2022 | 08:16 AM
Husky44's Avatar
Husky44
I NEED a Naro driver--even though I don't have this type of door trim. 😁
I always made one out of a screwdriver bit and vise grips.
Old Aug 17, 2022 | 01:05 PM
John Jordan
It is a very handy tool. Came in a set of bits.
Montana Miniac
Oct 26, 2012 09:05 PM
tutono
Apr 30, 2010 03:30 PM
Loony2N
Jun 27, 2007 12:16 PM
sanity29
May 16, 2005 01:13 PM
nexus66
Oct 14, 2002 08:51 AM
