R50/53 Would you buy a '06 with a p2096 code?
So it seems like we finally found a good replacement for our mini that was totalled last July now that we're on the east coast but it has a p2096 code. The guy said he's replaced the o2 sensor and just hasn't had the chance to get the code cleared.
It has about 80k miles on it. What are your thoughts?
What state are you in?
Kinda makes a difference....some let you pass with one item not ready, etc...
I would consider the fact that the o2 sensor might not be the cause...
Often a bad gasket on an exhaust, or cracked header pipe, etc is why there is a code....work it into the price...
Maybe. But a code reader from AutoZone is only around $60, which will also clear codes, and you'd think a seller would do so before making promises on finished repairs. Also, it's good tool to have around.
That's the hard part...it needs a pro level tool...or this..
Originally Posted by David.R53 View Post
I've bought from this guy. Still, be careful - I installed it on a junker Win7 laptop I don't use for anything important. Comes with the software and cable. The seller even helped with install problems. Start reading about how to use inpa and dis. This is the dealer software that can do everything ... Even program new keys if you have the patience to learn how.
BMW USB OBD Diagnostic Cable Inpa Ediabas Ncsexpert Dis V57 SSS V32 Progman GT1 | eBay
I've had a P2096 since installing exhaust. I'm sure it's a leak somewhere but haven't had a chance to really track down. I'm really use to driving it with that light on.
If it works for you, I'd talk him down. You may still fall under an O2 warranty and the dealer may take care of it.
Sure...sometimes a cheap aftermarket o2 sensor can cause it...but it's a different issue in most cases.
IQRaceworks
Nov 29, 2018 07:36 AM
Navigation & Audio Mini Cooper HiFi system finally completed.
spikeyadrian
Mar 18, 2016 07:24 AM
