R50/53 Why does the car feel amazing first start up of day compared to later drivng.
Old May 21, 2016 | 09:36 PM
Daredeezy619's Avatar
Daredeezy619
Can somebody explain to me why the first start up of the day, running at operational temp, feels stronger than if its already driven for a couple hours. I'm running ALTA %17. Megan Intake. And 380cc injectors untuned.
Old May 21, 2016 | 11:40 PM
nshannon29's Avatar
nshannon29
Heat soak more than likely. You might also try another intake that is actually inclosed. I know the feeling your experiencing I think. I had a Megan intake also and it felt sluggish at some points to. Went back to the stock intake and then the ddm works intake and feels better now.
Old May 22, 2016 | 02:08 AM
Daredeezy619
I'm wondering if i should go back to stock intake for now until i get the ddm or just mod my stock airbox.Gonna miss that loud SC whine for awhile =(.
Old May 22, 2016 | 06:37 AM
bavmotors's Avatar
bavmotors
Try the cowl mod, see if that helps. I had the Megan for awhile and had no issues. I have the open top Alta now and that deletes the cowl all together for more air flow.
Old May 22, 2016 | 10:54 AM
Ol' Blue's Avatar
Ol' Blue
You can revert to stock and do a little modification to still give you the same affect for quite a bit less if you're willing. I did it to mine and don't see any reason to go spend triple the amount of money on a name. If you have any questions about it just ask.
https://www.northamericanmotoring.co...ir-intake.html
Old May 22, 2016 | 11:01 AM
ZippyNH's Avatar
ZippyNH
I'd bet it mostly heatsoak...
But moving to an enclosed airbox would help...I used Dinian but they are kinda rare now...
Alta does make covers for their CAI to help seal the engine heat out...
Old May 23, 2016 | 08:57 AM
+1 heat soak or maybe as the car warms up one of the intercooler boots or intake boots is loosening up or has a hairline crack.
2010CHILI
Oct 5, 2016 09:45 AM
broofurd
Jun 22, 2016 10:31 AM
mbwicz
May 31, 2016 05:47 PM
ggv
May 27, 2016 01:05 PM
schwac2
May 20, 2016 12:16 PM
