Navigation & Audio Y Cable
Old Apr 30, 2016 | 04:49 PM
iivignale's Avatar
iivignale
Y Cable
Are there any other Y cables with lightning connection on the market that aren't 100+ dollars?
Any other alternatives?
I've got a 2012 R56 and use an iPhone 6.
Thanks!
Old Jun 8, 2016 | 07:27 AM
JohnnyZenith's Avatar
JohnnyZenith
I also want to know but for Android.
Old Jun 8, 2016 | 07:58 AM
rkw's Avatar
rkw
Android isn't supported on the R56. All you can do is use the aux input, or a thumb drive in the USB.
Old Jun 8, 2016 | 10:01 AM
JohnnyZenith
I don't understand sorry. I have seen BMW Mini Y cables for android but I am preferably looking at a Bluetooth receiver. I have one but although I was told it would work, it does not.
I am looking at hooking up my android tablet and android phone to the car. If this is impossible (I find that cannot be true) then I will sell the car.
Old Jun 9, 2016 | 09:22 AM
perryinva's Avatar
perryinva
WTF? unless the R56 is greatly different than the R55, Tune2air and the correct BMW Y cable work perfect for BT music, streaming or playlist, regardless of Android or iphone based. Both are usually had for about $85.
Old Jun 9, 2016 | 10:04 AM
TWISTER's Avatar
TWISTER
I found one on ebay for $70
Old Jun 9, 2016 | 10:07 AM
rkw's Avatar
rkw
Which Bluetooth receiver do you have and how are you using it?
I was responding to JohnnyZenith's original question regarding a Y cable for Android. The short answer is that there is none (BMW Y cable is only available with an iPhone connector). Bluetooth wasn't brought up until his second question. Yes, a workaround is possible by using a Bluetooth dongle.
Old Jun 9, 2016 | 10:19 AM
perryinva's Avatar
perryinva
Ahh. Sorry, my bad! Yes, you are completely correct, no direct wired solution except iPod. I read his BT comment and extrapolated.
Old Jun 9, 2016 | 11:42 AM
JohnnyZenith
Hi. I am using or trying to use the:
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
Bluetooth Receiver, TaoTronics Portable Wireless Audio Adapter
All I get is static.
I have seen a BMW Y Cable (third party for android) but it probably doesn't work. In any case it is Bluetooth I want to use.
I have no idea why this doesn't work.
Thanks for your reply,
Old Jun 9, 2016 | 11:45 AM
JohnnyZenith
I'll take a look at Tune2Air. I just wanted to use my phone and tablet and I cannot believe what I have to go through.
Perhaps my USB and AUX aren't set up properly.
My radio makes no warning sounds but i doubt this is part of it.
Old Jun 9, 2016 | 12:27 PM
rkw's Avatar
rkw
JohnnyZenith,
I replied to your post in the other thread:
Describe all the steps you did to set it up the Taotronics.
I see no reason why it shouldn't work. It is a simple Bluetooth receiver with an audio out. Do you hear anything when you plug headphones into the Taotronics? If you don't hear anything, it won't work on the car aux input either.
If it works with headphones, you should be able to swap the headphones with a connector into the aux-input jack, and select aux on the stereo.
Old Jun 10, 2016 | 03:21 PM
JohnnyZenith
Yes the Bluetooth receiver works. It appears to be the car.
I wonder if this is related to the fact I get no car sounds either. No chimes. My radio and CD works though.
Old Jun 10, 2016 | 04:13 PM
rkw's Avatar
rkw
Make sure that the plug is fully inserted all the way into the aux jack. If it's fitting tightly, this might not be obvious.
One final test to verify that it's the car... if you have a stereo cable with male at both ends, connect it between the aux and your phone's headphone jack (this is the typical usage of the aux in).
Old Jun 11, 2016 | 01:04 AM
JohnnyZenith
Yeah I've tried all that and no I get nothing out of the AUX. I guess I'm going to have to take the whole dash apart just to check this.
This has been a nightmare really. I should make it clear I have Android devices if that makes any difference.
I want my chimes and I want my MP3/Music.
Thanks for the advice so far.
Blueberry03MC
Oct 5, 2013 09:14 PM
texasmontego
Electrical
Jul 11, 2012 09:52 AM
GeoffreyM
Jun 24, 2011 08:58 PM
prof330i
11
Jan 18, 2007 12:10 PM
