R50/53 Mixing coolant
Old Apr 29, 2016 | 02:21 PM
SmurfNinja's Avatar
SmurfNinja
Mixing coolant
What happens when you mix green coolant with the blue mini coolant?
Old Apr 29, 2016 | 02:27 PM
ZippyNH's Avatar
ZippyNH
Officially nothing....but YPU end up with an unknown mix that does not meet any specific specification.
Nothing will likely blow up...
But the cooling system is the most overlooked iten on MINI's...
Gen1 cars with a cast iron block need a flush/drain and fill every 4 years....go too long, the rust collects (usually) in the heater core...so you losse your heat, then the headgasket tends to go....
Old Apr 29, 2016 | 02:45 PM
SmurfNinja's Avatar
SmurfNinja
It's currently 50% blue and 50% green. I hear that the mix will make a jelly like substance that will plug everything up. If this is true I'm assuming I have to flush it out asap?
Old Apr 29, 2016 | 02:53 PM
MINIAC's Avatar
MINIAC
The coolant is supposed to be mixed 50/50 with distilled water.
Old Apr 29, 2016 | 03:17 PM
ZippyNH's Avatar
ZippyNH
Naww...
That is orange and green makes jello......orange, aka Dex cool, is a ORGANIC ACID ...blue, and most every coolant made now (anything claiming to be long life ) is a hybrid OA, AND IS BACKWARD compatible, but that having been said, the mix does not meet any know spec.
Old Apr 29, 2016 | 05:15 PM
Fly'n Brick's Avatar
Fly'n Brick
Am I right in thinking that this idea sounds disturbingly like mixing bourbon and scotch? You can do it but why defile two independently perfect fluids.
Old Apr 29, 2016 | 10:59 PM
SmurfNinja's Avatar
SmurfNinja
It wasn't done on purpose. I went to two different mechanics for coolant problems and they each but in different color coolant
Old Apr 29, 2016 | 11:49 PM
Fly'n Brick
Ah ha, so, they changed bartenders and the second one wasn't paying attention. Got it.
Old Apr 30, 2016 | 05:12 AM
Shawnnn's Avatar
Shawnnn
Nice analogy!
Old Apr 30, 2016 | 08:57 AM
pkunk's Avatar
pkunk
You aren't in any immediate danger but a flush and fill with the approved blue stuff would be good to do
Old Apr 30, 2016 | 09:34 AM
SmurfNinja's Avatar
SmurfNinja
Great answer. Thanks!
quickcoop
Dec 4, 2020 09:05 AM
Eurothrasher
May 18, 2016 08:09 AM
MiniVoid
Apr 18, 2016 08:31 PM
Mar 24, 2016 11:31 AM
MiniDad08
Mar 23, 2016 01:59 PM
