R60 2012 Mini Countryman S Rough idle
Old Apr 10, 2016 | 06:03 PM
Dchap72's Avatar
Dchap72
Good Evening,
I am new to this forum as well as a new Mini Countryman owner.
I recently purchased a 2012 Mini Cooper Countryman S w/61,225 miles. When I start it, it starts fine but within 1 min., the RPM's drop, and the car starts to idle irattic for about 1.5-2 minutes then smooths out and is fine. Last week, check engine light came on so I took it back to the dealer yet again. In short, they found that the fuel pump needed to be replaced as well as needing new plugs. This morning, I started it up and the same symptoms are there. In fact, I started it up this evening and still had the same fires right up then within a minute, RPM drop, rough irattic idle.
Has anyone else on here had this issue? I forgot to ad, I did put some 44k in the tank about a week ago hoping that would help with carbon in the injectors.
Any help on this matter would greatly be appreciated.
Old Apr 10, 2016 | 08:06 PM
minicountry's Avatar
minicountry
Originally Posted by Dchap72
Good Evening,
I have the same symptoms as your, but no check engine light and the first thing come to my mind is the HPFP...please let me know when the dealer figure it out. Thanks
So the dealer replaced the high pressure fuel pump and it still do that??? Ignition coils? Is your Mini still under warranty and they replaced under warranty??
Old May 1, 2016 | 04:25 PM
wlambertr60's Avatar
wlambertr60
Good Evening,
Mine is also doing the exact same damn thing! Mine is a 2012 countryman it did the same thing on every cold start but if I gave it a little throttle it smooths right out but idont have any power loss but I do have the cel on it wasn't come on the first few times it did this but one day it did randomly and gave me all cylinder misfires in 1 2 3 and 4. Think it's the pump going out too but not sure I'm having it serviced this Thursday under warranty so I hope replacing my fuel pump will help the problem.
Old May 1, 2016 | 06:09 PM
minicountry
Going in next week at Mini dealer...so let see what they find out.
Old May 1, 2016 | 06:15 PM
wlambertr60
Yeah I'm going in on this Thursday and dropping it off and getting a loaner car I'm also tuned with a few mods but that's it. I have evo plugs in running.
Old May 13, 2016 | 12:29 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
HPFP being replaced today under the 10 year 120,000 coverage, yeah! Only cost is for a new serpentine belt they say is cracking.
Old May 13, 2016 | 12:52 PM
wlambertr60
Just got mine back the other day from,mini and they replaced my fuel pump but it still has a rough cold start idle to it.
Old May 13, 2016 | 12:55 PM
Minnie.the.Moocher
Did they do HPFP? Maybe you need the other pump replaced as well?
Old May 13, 2016 | 02:33 PM
minicountry
Carbon build up and valve, spark plugs tube gasket leaking...now all good to go
Old May 13, 2016 | 02:37 PM
wlambertr60
They replaced my hfpf and the sensor for it as well. How many miles do you have on yours? Maybe I should tell my dealer ship this is what fixed someone else's
Old May 13, 2016 | 03:24 PM
minicountry
2011 with only 63k km,and cleaning up the carbon buildup wasn't covered on my extended warranty, it's under maintenance , the walnut shell blasted the valves. But the seals and gaskets was covered. Plus they replace my comfort access on my door handle too, it wasn't working.
Old May 13, 2016 | 03:31 PM
wlambertr60
Yeah mine is 2012 with 43000 how much did it cost for the carbon blasting??? Yeah I had my hpfp replaced and the sensor for it they also fixed ny trunk for free. It wouldn't open at all. So what all did you have done to fix your problem? I feel like it's only on our 2011 and 2012s
Old May 13, 2016 | 03:42 PM
minicountry
All have this problems, make sure no leaky seals, 730$ Canadian but since they replaced the valve gaskets they reduced the labor so I pay 520
MidwayMountaineer
Jun 27, 2022 07:39 AM
quickcoop
Dec 4, 2020 09:05 AM
808R53
Detailing 101
Mar 18, 2016 04:49 AM
MazMini
Mar 17, 2016 11:38 AM
Lewis Lee-Martin Williams
Mar 14, 2016 07:36 AM
