R56 knocking noise
Old Apr 5, 2016 | 08:20 PM
nels415's Avatar
nels415
knocking noise
Hi all,
I started getting a knocking noise from what sounds like it's coming from the suspension. It sounds like it's coming from the left front, but passengers in my car said it may also be coming from the rear.
The knock sound occurs when I accelerate abruptly or when I let off the gas abruptly.
I just recently got new suspension work done, and had the mechanic check everything while they worked on it. They couldn't find anything wrong. The knocking noise was there before all the new suspension work was started, so it's not anything they might have left loose.
A couple of months ago, I changed out the the shifting mechanism for a tyrol short shifter, I may not have torqued the transmission bolt to spec. Could this be the culprit? I can't recall whether the sound started around that timeframe.
-nels
Old Apr 5, 2016 | 10:39 PM
renchjeep's Avatar
renchjeep
When an issue develops, I always go back and re-check the last thing I did. I would say you need to go back and re-check that trans bolt.
Old Apr 6, 2016 | 03:57 AM
cerenkov's Avatar
cerenkov
A common failure for suspension components are the swaybar endlinks. Relatively cheap and very easy to replace.
Old Apr 6, 2016 | 07:40 AM
Most common
https://www.northamericanmotoring.co...-the-back.html
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It sounds like it could be something bushing related. Endlinks are good to check, maybe check bushings on the sway bar itself. I've had bushings deteriorate on my p/s rack before, which caused the rack to shift under me during quick acceleration.
888.280.7799 | 6am - 5pm PST
Old May 9, 2016 | 07:28 AM
nels415's Avatar
nels415
So I finally had time to go back and check my transmission bolt that I loosened when installing the tyrol short shift kit. But no luck, it wasn't that, the bolt was tightened to spec.
Been trying to find threads similar to mine issue, could it be engine mount related? Other areas to check?
Old May 9, 2016 | 08:09 AM
grussell's Avatar
grussell
Did you replace the sway bar bushings and end links? I just helped a friend change their sway bar bushings and end links and their knock is gone!
Old May 9, 2016 | 01:42 PM
Systemlord's Avatar
Systemlord
Definitely sounds like a sway-bar bushing, often these bushing deteriorate and the solid steel sway-bar can move around causing a classic knocking sound. I had the same problem back when I had my stock rear sway-bar, decided it was time for a larger 25.5mm hollow rear sway-bar.
Old May 9, 2016 | 07:27 PM
nels415's Avatar
nels415
I have a new hotchkis 25 swaybar with their poly bushings. I believe my mechanic checked over all the suspension components to rule out the knocking noise from there. I'll take another look at the stock end links to see if there are any hairline cracks.
Old May 9, 2016 | 08:43 PM
Systemlord's Avatar
Systemlord
That's the one, put on the stiffest setting and never look back. Don't know why I kept it on the middle settings for so long.
JCW_Coupe
Apr 13, 2016 08:53 AM
seatosky
Mar 11, 2016 10:37 AM
thebombardier
Tires, Wheels, & Brakes
14
Mar 10, 2016 02:57 PM
SpuuDy
Mar 8, 2016 06:10 AM
