R50/53 2005 MINI Cooper S Serpentine Belt Seized
Old Apr 4, 2016 | 08:56 PM
AWDmaster's Avatar
AWDmaster
Hello all!
I work for a car dealership in Northern California, and today I purchased a 2005 Cooper S with 92k miles for the lot. We sell quite a few of these cars so I was happy with the purchase. The cars runs and drives great!
Today I drove the car from Reno NV to Sacramento CA (about 130 miles) and everything was going great until I was about 10 minutes from home.
I came to a stop light, and on green I started to accelerate when all of a sudden the battery light and check engine light came on. At that moment the car lost all power. It would idle fine, but even at WOT it would barely move. I got it to the nearest safe area to pull off the road and it started to overheat. I immediately turn the heater on full blast and turn the car off.
After it sat for ~15 minutes, I fired it back up and saw that the serpentine belt wasn't moving at all. The crankshaft pulley bolt was spinning but the pulley itself wasn't moving at all.
I am just wondering if this has happened to anyone before and what the problem/fix ended up being.
Thanks in advance for any help!
Old Apr 5, 2016 | 03:13 AM
JAB 67's Avatar
JAB 67
Bad crank damper.
Old Apr 5, 2016 | 07:35 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The harmonic balancer is one of those items on the MINI that seem to be a "when it fails, not if it fails item." When the balancer fails, it separates into two pieces, causing all of the accessory items driven by the serpentine belt to stop spinning. However, the harmonic balancer was redesigned for the 2004 model year to address a problem with the old design. I'd investigate further. Did you smell burnt rubber? This is what the one in our R53 looked like. Here if needed: http://www.pelicanparts.com/catalog/..._pg1.htm#item1. More info on it in this NAM thread HERE.
888.280.7799 | 6am - 5pm PST
Old Apr 5, 2016 | 12:39 PM
ti22fjc's Avatar
ti22fjc
I had this happen to me, too. Lost power and threw a few lights. My pulley was spinning and slipping.
Replacement wasn't too bad.
Old Apr 5, 2016 | 12:50 PM
Mini Mania's Avatar
Sorry to hear that, AWDmaster. You might want to check out the install info for a new one, especially the part about replacing the timing cover oil seal along with the damper, at this link:
http://new.minimania.com/MINI_Cooper...c_Fluid_Damper
Here are few more articles and optional dampers to choose from. Let us know if we can help!
http://new.minimania.com/MINI_Cooper_Harmonic_Balancer
Rons02JCW
Oct 21, 2016 01:08 PM
GimmeBoost
Mar 8, 2016 12:35 PM
Mrdrmini
Mar 1, 2016 07:45 PM
Dudskie
Feb 25, 2016 03:27 PM
Whale
Feb 20, 2016 10:52 PM
