F55/F56 Check engine light came on
Old Feb 19, 2016 | 07:51 AM
Dudskie's Avatar
Dudskie
I'm a new and first time owner of 2015 Cooper 4dr S auto. Check engine light came on yesterday, constant. Only 635 miles. Check fuel cap and it clicked one time so its tight. I went to set info, then check Info.......,"Check OK" lit up. How do I run the OBC to get the code? I don't feel comfortable driving the car to the nearest dealer which is 150miles away. Will probably call the roadside assistance. This is frustrating for a brand new car.
Old Feb 19, 2016 | 08:36 AM
Ryephile's Avatar
Ryephile
You're saying the CEL came on, you got out, verified the fuel cap, got back in, and the CEL went off? ...and there's still no CEL? ...and the car is driving fine?
Do you have an OBDII scan-tool? There might still be a freeze frame or a pending code. Posted OBDII codes often need 5+ error-free engine on/off cycles before clearing themselves. What you observed doesn't sound like a posted code, but something random and transient.
Before getting all uncomfortable and frustrated, at least call your dealer service department and explain the exact situation. They're there to help. Don't call Roadside for a perfectly drivable car.
Old Feb 19, 2016 | 08:47 AM
Dudskie's Avatar
Dudskie
The cel is still on/lit after checking the gas cap. It's still on. No I don't have an OBDII scan tool. My situation is a little bit not so convenient to call my dealer service department because I bought the car from a different state (west cost) and I'm live in the South. But yes I did call the dealer but I haven't heard from them yet.
Old Feb 19, 2016 | 08:52 AM
anotherminiinthegarage's Avatar
Some auto parts stores will scan for free
Old Feb 19, 2016 | 08:53 AM
Ryephile's Avatar
Ryephile
Ok, CEL still on. Where are you located? Chances are someone here can meet up with you and read the OBDII for you. ...or go to an Auto Zone and borrow one for free.
The service department will fix your car under warranty regardless where you bought it. They get paid no matter what. Keep calling them.
Old Feb 19, 2016 | 10:39 AM
Dudskie's Avatar
Dudskie
Mississippi. Yes I will keep calling them. I'm hesitant driving the car to the nearest dealer 150miles away, because I don't want to give them any reasons blaming me for having caused further damage to the car since the check engine light in on. Thank you
Old Feb 19, 2016 | 11:41 AM
Ryephile's Avatar
Ryephile
I understand your hesitation, but that's not how OBDII CEL works. A solid light means there's a non-critical, usually emissions related tolerance or fault, and the engine is generally fine to drive. A flashing light means a function-critical fault has occurred, which you would know about, since the engine would die and either go into limp-home or leave you stranded. The latter is definitely not common.
Head to an auto parts store that'll loan you a code reader, and then talk with your dealer over the phone. Post the code here and we'll try to help.
Old Feb 19, 2016 | 11:54 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Sorry about your frustrations. Any other symptoms you notice besides the CEL? Ryephile is right that a scan tool will be your best idea as it will be able to pull the code triggering the CEL. If you do pull the code you should be able to get an idea of how serious it is. Let us know what you find.
888.280.7799 | 6am - 5pm PST
Old Feb 22, 2016 | 05:30 AM
Dudskie's Avatar
Dudskie
Just an update. I talked to the service advisor of the nearest Mini dealer and was advised to send the car to them thru roadside assistance. They will pick the car today. Anybody used the roadside assistance before? Are they pretty good handling the car? Thanks
Old Feb 22, 2016 | 06:05 AM
Tikigod's Avatar
Tikigod
When I used it, mini subbed the towing (flatbed) out to a local company, who did a great job, course I was watching during the loading and unloading process.
Old Feb 22, 2016 | 07:01 AM
Dudskie's Avatar
Dudskie
Yes, mini sub the towing with the local towing company, I will be present during the loading but will not be there at the dealer when unloading the car. I will just communicate with the service advisor thru phone. Any advice so it will be a smooth repair?
Old Feb 22, 2016 | 07:42 PM
Mrdi's Avatar
Mrdi
Go with the tow truck and get a loaner from Mini
Old Feb 23, 2016 | 07:24 AM
vetsvette's Avatar
vetsvette
Moderator
^^^ What he said.
Old Feb 24, 2016 | 05:47 AM
Dudskie's Avatar
Dudskie
Guys, thank you for all your advices, but to make the story short, the towing company that BMW contacted to tow my car to the dealer back out coz it's too far (150miles), waited for an hour and did not show up at all or call that they are not coming at all. I'm not glad that they didn't make it because when I park my car back to the carport the check engine light is gone. Now I so excited again driving the car, no worries. Again thank you.
Old Feb 24, 2016 | 02:38 PM
hammerhands's Avatar
hammerhands
You should get an OBDII tool, keeps your peace of mind. I've got a bluetooth one that works with my iPod.
I've had the light come on a couple of times as the car starts up for a crankshaft position sensor. It clears after you start the car a couple of times. I've told the dealer and they did not seem concerned.
I had some more dramatic issue last week that involved a tow and a fix, you could tell by the codes that it was real trouble, oxygen sensor, misfire on multiple cylinders. That and the car was heaving like it was bucking horse.
Interestingly, they show up as Land Rover specific codes, according to the app.
Old Feb 24, 2016 | 08:17 PM
LostDenverite's Avatar
LostDenverite
Which one?
Old Feb 25, 2016 | 06:01 AM
Dudskie's Avatar
Dudskie
And where did you get it?
Old Feb 25, 2016 | 11:41 AM
Get this one it does F56+ and is MINI specific at reading stored codes and normal codes. You can select F56 models.
https://www.northamericanmotoring.co...2-scanner.html
Old Feb 25, 2016 | 03:07 PM
hammerhands
I got a GoPoint BT-1 from eBay for $25. I don't think you can get a deal like that.
I'm using DashCommand and the app for the scanner.
Old Feb 25, 2016 | 03:27 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Go to Autozone, NAPA or some other local parts store or garage and see if they can scan the code for you. Its pretty easy and a heck of a lot easier then dealing with tow trucks, loaner cars etc..
It takes 2 seconds for them do scan it. It will save you a lot of stress
j_vincent
Feb 14, 2016 12:31 PM
supermini23
Jan 31, 2016 04:15 AM
gknorr
Jan 29, 2016 10:06 AM
Semaphore
Jan 26, 2016 07:58 AM
DivineXtacy
Jan 24, 2016 05:52 PM
