R50/53 Adding a Chrono Pack to R53
Old Apr 4, 2016 | 03:33 PM
SmurfNinja's Avatar
SmurfNinja
Hey guys, my 2003 R53 has the Nav in the center spot, a speedo, and tach above the steering wheel. My question is it possible to replace the Nav with a Chrono Pack with to my knowledge has a boost and temperature gauge? Or if it would be cheaper to just buy the gauge and add them above the steering wheel. Or any other options out there, I'm mostly looking for a boost gauge and some other useful gauge to tell if my car is healthy at an affordable price.
Old Apr 5, 2016 | 05:22 AM
rwkeating's Avatar
rwkeating
I don't know how possible it is to install a chrono pack, but that package does not have a boost gauge. It contains a fuel gauge, coolant temperature, oil temperature and oil pressure. According to everything I've read, the oil temperature is a calculated value (not measured) as no one has found an oil temperature sensor on the engine.
Old Apr 5, 2016 | 07:17 AM
bavmotors's Avatar
bavmotors
Yea sadly no boost gauge, pretty lame. The only thing nice about the chrono is having the speedo above the wheel. From what I've read I'm not sure you could even get the swap to work flawlessly anyways.
Old Apr 5, 2016 | 07:21 AM
Helix13mini's Avatar
Helix13mini
You'd have two challenges, the wiring to the accessories and the coding of the Kombi (the dash control unit). Where there's a will, there's a way, but you will have to have one heck of a will to get this done.
Old Apr 5, 2016 | 08:08 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Some good info in these NAM threads HERE and HERE.
888.280.7799 | 6am - 5pm PST
Old Apr 5, 2016 | 11:55 AM
SmurfNinja's Avatar
SmurfNinja
Ok so no chrono. How do I go about adding a boost gauge when I already have my speedo and tach above steering wheel
Old Apr 5, 2016 | 11:56 AM
PelicanParts.com
Vendor
Can go with the P3Cars vent gauge. I run my boost gauge in my vent. Can check it out HERE.
Old Apr 5, 2016 | 12:05 PM
bavmotors's Avatar
bavmotors
yes those are very cool, there is also gauge pods that fit in the vents for your choice of gauge.
Old Apr 5, 2016 | 12:24 PM
Mini Mania's Avatar
Hi, SmurfNinja:
There are some quality gauge kits available and an application guide, which can be found here. Let us know if we can help!
http://new.minimania.com/part/NMI731...2-53-Cooper--S
Old Apr 6, 2016 | 09:15 AM
SmurfNinja's Avatar
SmurfNinja
Awesome I think I'm going to buy one of these. Which vent do most people put it in. From pictures it looks like they use the one closer to steering wheel but when driving I feel like I wouldn't be able to see it. Thinking about using the passenger side vent. Any thoughts?
Old Apr 6, 2016 | 10:20 AM
PelicanParts.com
Vendor
Could work, if you think you'd like that position more. Mine's in the drivers vent as I rarely ever look at it unless I'm curious as to what PSI it's hitting at WOT from time to time. My more important gauges, oil pressure and AFR are mounted where they're visible. However, the P3 gauge is much more universal than a single gauge as it's a multiple display gauge so you have more you can view other than boost.
Old Apr 6, 2016 | 11:10 AM
MINIAC's Avatar
MINIAC
Aeroforce Interceptor plus Cravenspeed Z Bracket and 52mm Gauge Pod is another (slightly cheaper) option.
Old Dec 1, 2018 | 12:29 PM
mountainhorse's Avatar
mountainhorse
Last edited by mountainhorse; Dec 1, 2018 at 03:23 PM. Reason: Moved it to its own thread
Old Dec 4, 2018 | 12:55 PM
Hecka's Avatar
Hecka
I swapped my 06's gauges with chrono gauges and they work as intended, although the DSC and TPMS lights are permanently on and there's no way I have found to turn these lights off/enable these services. The swap itself was very simple, but the trim above my steering column wouldn't fit back on with the dual gauges on top. I just left the trim off and it's not so noticeable. I would like to eventually mod my trim or get a trim piece that fits the dual gauges.
Old Dec 4, 2018 | 10:13 PM
ItsmeWayne's Avatar
ItsmeWayne
It is like they say:
water temp, oil temp, oil pres and gas gauge
I think it can not be installed, but the nave can show gauges with some kit.
this is a video of the nav with OBDII kit
KatieTronR53
45
Sep 1, 2016 10:20 AM
beemboy
Mar 14, 2016 11:10 AM
Saovalle
Tires, Wheels, & Brakes
20
Mar 9, 2016 04:18 PM
CamPorta
23
Feb 24, 2016 08:21 AM
Greerj1987
Feb 23, 2016 06:51 AM
