P00BD code ?
Old Apr 3, 2016 | 02:30 PM
mtnmikev's Avatar
mtnmikev
P00BD code ?
Hello all, My 2012 countryman has had an intermittent shudder when accelerating up grades. Always at the same altitude, usually with no check engine light, but I had one once with no limp mode. I got to where I was going and when I started the car again it was gone.
Today while going up the same grade in the same spot it shuddered hard! CEL came on and I have my OBD2 and dash command so I read a P00BD code and the car went in limp mode. Simple replacement of Mass Air Flow sensor? I did find that my tubing into Mass Air Flow was not seated right up against the lip, don't know if that would cause this.
Anyway any and all input will be appreciated!
Thanks,
Mike
Old Apr 3, 2016 | 03:14 PM
cerenkov's Avatar
cerenkov
Do you have an aftermarket intake with an oiled filter?
Either way, I'd try cleaning the MAF with MAF cleaner before spending money on a new one.
Old Apr 3, 2016 | 03:55 PM
mtnmikev's Avatar
mtnmikev
I have the AFE filter. No oil. I'll try a clean of the MAFS.
Old May 30, 2016 | 10:39 AM
roadredmini's Avatar
roadredmini
not having the oil filler cap screwed on right can bring up the engine light, also can cause slightly lumpy running.
Rons02JCW
Oct 21, 2016 01:08 PM
GimmeBoost
Mar 8, 2016 12:35 PM
Mrdrmini
Mar 1, 2016 07:45 PM
Dudskie
Feb 25, 2016 03:27 PM
puwit321
Feb 22, 2016 11:57 AM
