R60 R60 Harman/Kardon subwoofer failed?
Old Mar 21, 2016 | 11:16 PM
pico33's Avatar
pico33
Hi everyone,
I have a Harman/Kardon system in my 2014 R60, but how to run the test on the subwoofer which under the seats?
I can't hear any bass from there, I am wondering, do the subwoofer turn off when the car in lower speed or parking? or it is just not working? or the amp problem?
please let me know if you have the same Harman/Kardon in your R60.
Thanks!!!
Old Mar 22, 2016 | 11:11 AM
hello,
Do you have it under warranty? The woofers are on once you turn the radio on. They dont turn off on there own.
If you have the schwaben tool you can test each speaker, otherwise they are on the same channel on the front , but you can test them by putting you hand on them and useing the balance from left to right also.
If you have a fail amp and out of warranty for some reason : 65129388960
https://www.ecstuning.com/Search/SiteSearch/65129388960/
Old Mar 22, 2016 | 03:42 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you possibly turn the bass setting down by accident? Try setting that on high.
Old Mar 22, 2016 | 07:19 PM
pico33's Avatar
pico33
hello,
Thanks for the information!!
I tried to put my hand and a thin layer of paper on each speaker, but only the subwoofer (under the seats) have no movement.
I still under warranty, I will bring it back to the dealer for checking.
Does many people order the amp from you? i just wondering, will it easy to break-down like mine.
Old Mar 22, 2016 | 07:20 PM
pico33's Avatar
pico33
I did turn the bass setting all the way to the highest, but nothing happen.
Old Mar 23, 2016 | 08:26 AM
Welcome.
The H/K amps dont fail that oftern on the Gen 2 MINI, it was mostly a Gen 1 MINI ( older MINIs ) problem.
You might just have a bad channel on the amp or something. Post up what the dealer finds . Thanks
Miniac 1964
14
May 24, 2026 08:07 AM
ludrof11
R60/R61 Stock Problems/Issues
17
Apr 3, 2018 02:55 PM
TxMINIMama
Mar 7, 2016 09:15 AM
Dan8980
Feb 25, 2016 11:45 AM
Braminator
Test Forum
Feb 22, 2016 06:43 PM
