R56 Advice on purchasing a used MCS
Old Mar 11, 2016 | 01:02 PM
Bponce23's Avatar
Bponce23
Hi,
I'm looking to purchase a used MCS (automatic) with about 65k miles. According to the seller it's been maintained at a BMW dealer. All recalls and TBS have been taken care of.
Question is, What should i look out for with a high mileage MCS? what should i be checking for?
Old Mar 11, 2016 | 04:36 PM
AZdsrt's Avatar
AZdsrt
What year? Makes a big difference..
Old Mar 11, 2016 | 05:19 PM
thebombardier's Avatar
thebombardier
Probably the most important factor in buying an R56 even ahead of mileage.
Old Mar 12, 2016 | 06:42 PM
SPRINTCARS's Avatar
SPRINTCARS
Make sure the HPFP is good. It seems with the infinite wisdom of mini corporate they've literally tripled the price of these fuel pumps. My cost was 287. It's now 1243.00. That right there, to me, makes it not worth owning anymore. Parts are way to much to fix a car that's basically 7 years old now
Old Mar 13, 2016 | 06:08 AM
gjxj's Avatar
gjxj
is there a way to check it?
Old Mar 13, 2016 | 06:54 AM
Mini3333's Avatar
Mini3333
+1
I agree
Old Mar 13, 2016 | 12:18 PM
oldbrokenwind's Avatar
oldbrokenwind
Originally Posted by Bponce23
Hi,
If it's not too late, avoid the N14 engine! Even with all the problem parts being replaced, the replacement parts aren't that much better. N18 engine or maybe 3rd gen cars would be a better choice.
Old Mar 15, 2016 | 12:43 PM
Bponce23's Avatar
Bponce23
lol wow I dumbed out.. one is a 2009 and the other is a 2011!
Old Mar 15, 2016 | 01:48 PM
AZdsrt's Avatar
AZdsrt
All things being equal, skip the 2009. Lots of known problems with the early 2nd gen with the n14 engine. Starting in 2011, they used the n18 engine, far fewer reported problems.
Old Mar 15, 2016 | 02:15 PM
Mini3333's Avatar
Mini3333
I agree with the above.
The 2009 MINI Cooper S has the N14 engine... lots of problems to include: oil consumption, carbon build-up and timing chain issues. Only buy if you're a mechanic and you get a good price on the car.
The 2011 MINI Cooper S has the N18 engine...not perfect (no car is), but huge improvements.
Old Mar 15, 2016 | 02:22 PM
I would try to go towards the N18 if you can also the 2011+ MINI have more black interior options and an updated interior look. Exterior was updated also on taillights and such. 2011+ was the LCI version.
Old Mar 15, 2016 | 10:44 PM
renchjeep's Avatar
renchjeep
JCW continued with the N14 until 2013, I believe. Definitely look for an N18. As said previously, not problem-free, but a BIG improvement over the N14.
Old Mar 16, 2016 | 05:41 AM
JCW n14 was till 2012. Then in 2013+ it was the JCW N18.
Old Mar 16, 2016 | 09:09 PM
renchjeep's Avatar
renchjeep
Thanks, ECS.
Old Mar 17, 2016 | 05:40 AM
no problem,
Old Mar 21, 2016 | 12:34 PM
Bponce23's Avatar
Bponce23
so is the carbon build up on the valves reduced or eliminated on the n18?
Old Mar 21, 2016 | 01:50 PM
Bponce23's Avatar
Bponce23
Old Mar 21, 2016 | 03:12 PM
Mini3333's Avatar
Mini3333
Really the carbon build-up is a minor problem that can be solved with a walnut shell blasting. You will get a check engine light...then spend a few hundred dollars and the prob will be gone.
Watch this:
In my opinion the timing chain and the possibility of massive oil consumption is the biggest risk with the 2009 MCS.
Again, the N18 engine is the best option, unless the price of the 2009 MINI S is low.
l1qu1d993
Apr 29, 2016 05:46 PM
GAT
Mar 11, 2016 11:08 AM
Lakehouse
Mar 11, 2016 07:44 AM
hsautocrosser
Tires, Wheels, & Brakes
Mar 10, 2016 08:52 AM
Turbo R53
Mar 7, 2016 01:36 PM
