Hi. I'd like to change out my shocks and springs to get a smoother ride. I don't track my car. I was thinking of going with NM springs, but not sure what shocks to go with. I am also not sure if I want to go lower. I am sure I don't want to go with coilovers. What would you guys suggest?
Reason: add information
I will probably get rid of runflats once my current tires are dead, but until then I will not be replacing tires. I currently have Bridgestone drive guards and the ride is night and day different compared to the Pirellis I had before then.
Absolutely. Losing the run-flats makes a significant difference, and the price is right when you have to replace tires anyway!
If you're not putting the car on the track, I really don't believe that you need the suspension work. But it makes sense to do the tires first; the suspension will still be there.
Non runflats cost half what runflats cost and last way longer. My runflats didn't last 30k miles on my 2007. You're probably not gonna get a softer ride changing springs.
Good point GS.
If you do go FSD's what with the lowering springs with those as Koni does not recommend it due to early failure with lowering springs. Suppose to run stock springs. The FSD do have the most comfortable ride, but you wanted to lower on top of that.
Good point GS.
I don't think I want to lower the car is what I had said.
I switched to FSD and non-runflats around the same time. The FSD's are a nice upgrade but, of the two mods, the tires made a significant more noticeable change in the ride quality.
Thanks for all the input. I have a good amount of tread left on my current tires so I will probably be getting Koni FSD and then change to non runflat tires. Has anyone had any issues with non runflat tires on road trips?
