Advice for stripped lug bolt hole
Old Feb 23, 2016 | 03:54 PM
FallenBike's Avatar
FallenBike
Hey all, so my front driver wheel only has 3/4 lug bolts at the moment. The lug bolt itself was stripped as well as the matching threads in the hole. I cant get a new bolt in there without new threads to screw into.
Does anyone have any experience with this issue or know the proper size and thread pitch tap that needs to be used? Any help regarding this will be greatly appreciated!
F.Y.I its an 09 JCW
Old Feb 23, 2016 | 04:31 PM
Drivehard's Avatar
Drivehard
Originally Posted by FallenBike
Hey all, so my front driver wheel only has 3/4 lug bolts at the moment. The lug bolt itself was stripped as well as the matching threads in the hole. I cant get a new bolt in there without new threads to screw into. Does anyone have any experience with this issue or know the proper size and thread pitch tap that needs to be used? Any help regarding this will be greatly appreciated! F.Y.I its an 09 JCW
Heli coil. 14mm X 1.25 is the thread pitch that you need to get. You will have to look in the helicoil kit to see what tap you need.
The REAL repair is a new hub. If it was a five bolt hub I would do a heli coil. I would have to question 1 of 4 bolts not 100%. But that is just me
You can get the repair kit on line relatively cheap
https://www.google.com/aclk?sa=l&ai=...71%26veh%3Dsem
Good luck
Old Feb 24, 2016 | 08:23 AM
+1 there 14x1.25
You could just replace the wheel bearing. I dont know how damaged the threads are but they do hold the wheel to the hub, that might be a safety concern.
https://www.ecstuning.com/Mini-2009-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Drivetrain/Wheel_Bearings/
Old Feb 26, 2016 | 05:22 AM
mini4mo's Avatar
mini4mo
I would go with a new hub.
To do a Helicoil insert that large,it would be best to remove the hub and do the repair on a vertical mill or drill press IMO.
DAVIDLEERAD
News
568
Sep 28, 2022 11:24 AM
jesse31
Feb 3, 2016 06:40 AM
J Free
Jan 28, 2016 09:21 AM
Eugene Arnold
R58 :: Coupé Talk (2012+)
Jan 26, 2016 10:13 PM
ThunderDolphin4
Jan 25, 2016 05:51 PM
