R60 Leaking coolant - what sensor is this?
Old Feb 17, 2016 | 08:08 AM
stevepsd's Avatar
stevepsd
The sensor (circled in red) is located below the coolant tank and is in a metal elbow. The sensor snaps into place (not threaded) and has a single o-ring seal which coolant is leaking past.
I believe this is the coolant temp sensor?
I checked the fische on RealOEM.com and cannot find this sensor listed and the coolant lines do not match what is actually on the car.
Old Feb 17, 2016 | 12:29 PM
stevepsd's Avatar
stevepsd
I found the fix over in the 'fixing problems and issues' subforum. Looks like a well known problem and I could not find the OEM parts listed as Mini/BMW has did away with this problematic setup.
https://www.northamericanmotoring.co...ntryman-s.html
Rock944t
Apr 4, 2020 10:22 AM
mini_aaron
Dec 25, 2017 04:22 PM
MazMini
Nov 19, 2016 10:09 PM
slipmagt
Mar 6, 2016 07:55 PM
buzzsaw
12
Feb 18, 2016 11:14 AM
