A small item you should check when detailing....
Old Jan 27, 2016 | 02:07 PM
SupeR53's Avatar
SupeR53
Check the condition of the rear hatch drains (R50 and R53), when I did a detailing on my '05 MCS recently, I found the drains (2 small rectangular holes at the bottom seam) were packed up with black, greasy glop. They weren't so bad that nothing could drain, but enough to to limit the amount and allow for water to puddle and possibly start corrosion at the hatch seam.
A little fettling with a small flat blade screwdriver opened them up again.
Just a heads-up that could save your hatch down the line.
Old Jan 27, 2016 | 02:42 PM
whaap's Avatar
whaap
Thanks for the info. Good job.
Old Feb 2, 2016 | 10:55 AM
crazy4trains's Avatar
crazy4trains
String trimmer line is excellent for clearing drains. Strong enough to clear the clog without doing any damage to any subsurface plumbing.
Old Feb 3, 2016 | 07:03 AM
Good mention , those other drains, the big ones are the drain tubes on top also.
https://www.northamericanmotoring.co...-problems.html
Old Feb 3, 2016 | 10:41 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Good find. Those drains getting clogged is somewhat common and can cause a whole hoist of water leak issues with your MINI.
888.280.7799 | 6am - 5pm PST
Old Feb 23, 2016 | 03:35 PM
Eric_Rowland's Avatar
Eric_Rowland
I'm at a loss - where are these small rectangular holes? In the hatch? In the body?
I see the two at the top of the body, but that's it.
Old Feb 23, 2016 | 03:50 PM
SupeR53's Avatar
SupeR53
They are in the hatch itself. If you open the hatch and look at the area of the hatch near the catch, they are about 12" each side of the catch right at the metal seam of the hatch.
HTH,
Old Feb 23, 2016 | 08:35 PM
Eric_Rowland
Huh - my late '03 build '04 only has one right at the latch D ring. TFTH.
Old Feb 24, 2016 | 06:46 AM
Its the little small holes in the hatch itself at the bottom of the seam to let water out , usually filled with a little grim an old wax coating from transposrt.
minicooperlover22
Jan 15, 2016 06:32 AM
turboman38
Jan 11, 2016 04:45 AM
elisebr53
Jan 7, 2016 12:18 PM
ApexinM3
Jan 7, 2016 11:51 AM
rphox2003
Jan 3, 2016 06:52 PM
