R56 Could this be a HPFP issue?
Found you guys after some extensive research on a recent problem I've been having.
My car: 2011 Mini (base/auto), with 34,500 miles on it.
It's started happening ever since I came back from a 5 day vacation.
Since 3 days ago, when idling, the engine starts to rattle and die. It'd do it This happens usually after a long drive and I come to a stop. After restarting the engine, I have to try put some acceleration so it doesn't die again, seems to die whenever RPM is less than 1k. I recall my engine stopped on every stop I took at one point yesterday. The symptoms are somewhat random but I feel they are increasing by the day. Temperature here is 60's in Socal. I wish I knew what makes these worse, perhaps long drives? High RPMs?
Anyhow, I took it the repair shop yesterday and he couldn't find what's wrong because there were no engine light at the time and we couldn't reproduce the issue at the shop while test driving. However, he did say that the repair might cost a lot of money (where he mentioned the parts alone could cost over $900!). But as I was driving home, the engine light came on and now it seem to be on all the time.
Here is video:
Here is video:
My questions:
1) I've read this could be HPFP and I hear it may be covered by warranty so I called Mini USA but they said I need to call dealership I bought it from. But I bought it used from a Nissan dealership a couple years back, do I call them?
2) Is it better for me to take this to dealer or should I just take it to local repair shop?
3) How much did it cost you for the repair?
4) Also, the repair guy said the problem may just go away on it's own if I keep driving it. How much of this is true?
The guy charges $125/hour and I think he spent a couple hours on it.
Did they pull the valve cover off. ? Looks like it was mostly labor for that amount.
