R50/53 Coolant expansion tank wont stop spitting
Old Jan 12, 2016 | 01:03 PM
Steffen.Johnson's Avatar
Steffen.Johnson
I am hoping someone can help me fix a slight problem I have noticed as the weather has gotten colder. I had a local shop install a water pump kit complete with new expansion tank, cap, coolant etc from ECS. Since the car has been back I have noticed some coolant being spit out around the cap I at first thought the mechanic had slightly overfilled it so I wipped it off and kept checking it. Recently I took the cap off and took some of the coolant out to the max fill line and whipped it all down again. Popped the hood today and still spitting a little bit of coolant out of the cap. I have been able to confirm there are no leaks anywhere else and it is only blowing out of the cap area..help me.
Old Jan 12, 2016 | 01:29 PM
You need to have all the air bled out. Might take a couple times. Since you did the cap and everything else , that section should be fine. make sure they did not over-tighten or strip the cap. I would take it back to them and have it re-bled. make sure you are to the fill line.
https://www.northamericanmotoring.co...erflowing.html
Let me know it you need anything else. I am here for you.
Old Jan 12, 2016 | 01:40 PM
Steffen.Johnson
Thanks for the quick reply. How exactly do you bleed the air out of the system?
Old Jan 12, 2016 | 01:43 PM
Post #47 at the bottom of that post on coolant flush:
https://www.northamericanmotoring.co...ush-diy-2.html
Old Jan 12, 2016 | 01:47 PM
Steffen.Johnson
Oh wow thats a little too much for me. So you are thinking the shop I had do it didn't flush it properly? Is it ok to drive around like this for a bit before I can get to the MINI shop?
Old Jan 12, 2016 | 01:49 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Info here in regards to bleeding the system. Otherwise, maybe give the mechanic a shout as I'm sure they warranty all work performed and can take care of it for you. At the shop I worked out we preferred if individuals encountered an issue to bring it back to us first so that we could correct it before someone else tinkered with things.
888.280.7799 | 6am - 5pm PST
Old Jan 12, 2016 | 01:51 PM
Yea, I dont want you to have a CEL or overheat issue if there is that much air (mdont know what the shop did ). I would carry coolant around mixed and watch it closely. It might burp itself down.
Old Jan 12, 2016 | 04:32 PM
Steffen.Johnson
I have been watching it diligently and no drop in coolant I honestly just think he overfilled it. I think tmrw I will syphon some more out and run it with the cap off to remove any bubbles. Thanks ! I will keep you all posted
Old Jan 13, 2016 | 04:58 AM
Thanks, keep me posted.
Old Jan 13, 2016 | 05:05 AM
Steffen.Johnson
Will do! Thanks!
Old Jan 14, 2016 | 11:21 AM
nkfry's Avatar
nkfry
Why did you replace the listed components?
The only reason the cap would bleed is if it is creating a faulty seal or the pressure in the cooling system is over 18 PSI, which would lead to investigate for a possible head gasket failure.
If the initial bleeds were done properly the car will self bleed as the expansion tank is the highest point of the cooling system. Once the majority of the air is out of the system you should really only have to top coolant off once at the most.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 14, 2016 | 06:13 PM
Steffen.Johnson
I replaced all of the components because it was part of the water pump kit. I had a bad water pump and themostat.
I think the reason the fluid was spitting is because the tank was overfilled I syphoned out the excess fluid and have been checking it daily and havent seen any new blow off.
In the past I overheated on the top of Mt Hood and had to drive the car off the mountain as it was overheating so I thought I may have blow the head gasket. But that was months ago and no sign since summer of any related issues. What are your thoughts?
Camaro108
Dec 15, 2015 05:02 AM
RocketUSA
Dec 10, 2015 06:37 AM
JPMontes3
Dec 3, 2015 10:05 AM
Colt45Magnus
Dec 3, 2015 08:53 AM
banyan
Dec 1, 2015 04:00 PM
