Interior/Exterior Exterior Trim Replacement?
Old Jan 12, 2016 | 12:33 PM
Roo92's Avatar
Roo92
Hey guys, so I need some advice from you all. My MCS is an '03 and her trim is starting to look a bit weathered. I use meguiars black plastic restorer on it and for a while it looks pretty good, however after a week it goes back to the weathered look.
I was looking into replacing all the trim for that brand new look but it's gonna cost a little over $700 for all new pieces. Should I bite the bullet or are there amazing restoring products out there I'm missing?
Thanks,
Roo
Old Jan 12, 2016 | 02:24 PM
You can keep apply VRP from CG, it will last longer then most.
https://www.northamericanmotoring.co...arch-fade.html
Or if the trim is beyond hope. Paint it , or replace it.
Old Jan 17, 2016 | 12:48 PM
jgk6502's Avatar
jgk6502
Are you cleaning your trim before using your restorer product? I usually use APC diluted 10:1 for medium cleaning and 4:1 for heavy. It really makes a difference on longevity when applying a plastic trim sealant and protectant.
Old Jan 18, 2016 | 06:15 AM
Yea, you have to get it clean with either car soap or a mild citrus greaser , just to get the blobs of tar or anything off first. Then apply the VRP on that clean surface.
Old Jan 21, 2016 | 04:38 AM
r7denz's Avatar
r7denz
Try also 303 protectant. It will give a clean look finish and has UV protection.
Old Feb 10, 2016 | 09:44 AM
mitchgixer6's Avatar
mitchgixer6
Gtechniq C4 gets good reviews. Worth a try before splashing out on new trim.
http://gtechniq.com/products/auto/pe...-trim-restorer
Old Feb 10, 2016 | 10:00 AM
I Used the VRP for some time on my old 250K+ trim, brings it back to life, but if you have deep chips and scares on the rear wheel arches , it hides some of them. If its gashed then you will need new arches.
r56lenore
Jan 3, 2016 03:29 PM
Bean0709
12
Dec 24, 2015 01:26 PM
Bearybee
Dec 24, 2015 08:31 AM
Cmv138
Dec 18, 2015 10:26 AM
Hendricksen
Dec 13, 2015 06:32 PM
