R60 Finding a spot in the firewall
Old Jan 9, 2016 | 10:15 AM
ludrof11's Avatar
ludrof11
As anyone installed aftermarket subwoofers or anything that attaches to the battery? I am going to be installing air suspension soon and was just looking at the firewall. The only spot I have found is where the wire harness comes through but looks pretty tight. Curious if people have made their own spot or found something else?
Old Jan 9, 2016 | 03:30 PM
bmwr606's Avatar
bmwr606
there are 2 pass thrus ... behind the battery and behind the brake fluid resoviour
there are rubber seals with "fingers" ... snip the end off an extra unused "finger"
Old Jan 9, 2016 | 03:34 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Can you provide details on the air suspension if you know them yet?
Old Jan 10, 2016 | 04:35 AM
ludrof11's Avatar
ludrof11
Originally Posted by bmwr606
there are 2 pass thrus ... behind the battery and behind the brake fluid resoviour there are rubber seals with "fingers" ... snip the end off an extra unused "finger"
Thank you. That's what I was assuming people used but didn't know!
Old Jan 10, 2016 | 04:37 AM
ludrof11's Avatar
ludrof11
I am using airlift performance 3p management and have bought the bags off of a friend that had an sti. I'm using old coilover mounts from my previous r56. The only companies I know of that make exact fit bags are k sport and airrex
Old Jan 11, 2016 | 04:05 PM
TJANK's Avatar
TJANK
The pass-thru that MINI recommends for installing their LED Daytime Running Lights. There is a rubber grommet covered by a hard plastic cap. The rubber grommet has two tabs sticking out that you can cut off showing a passthru to the inside of the car. The following is from those instructions.
Also, the following video at time of 4:36 shows the grommet and the plastic cover.
Old Jan 16, 2016 | 04:41 AM
ludrof11's Avatar
ludrof11
Originally Posted by TJANK
The pass-thru that MINI recommends for installing their LED Daytime Running Lights. There is a rubber grommet covered by a hard plastic cap. The rubber grommet has two tabs sticking out that you can cut off showing a passthru to the inside of the car. The following is from those instructions. Also, the following video at time of 4:36 shows the grommet and the plastic cover. Video Link: https://youtu.be/f9LGYVBU3Sg?t=279
Thank you worked perfectly!
Old Jan 20, 2016 | 05:53 AM
+1 TJank hit it right on. Should fit a pretty nice size gauge wire.
kgelner
R60/R61 Stock Problems/Issues
Aug 13, 2017 05:24 PM
KilmerPT
Feb 29, 2016 07:57 AM
jdurgam
Jan 12, 2016 02:32 PM
goin2drt
Jan 10, 2016 05:59 AM
Kid_Organic
Jan 6, 2016 07:40 AM
