Leak from coolant temp sensor on elbow 2012 countryman S
Old Jan 6, 2016 | 05:58 AM
daonlyillwiz's Avatar
daonlyillwiz
As the title states I have a leak coming from the temperature sensor on the metal elbow on my 2012 countryman S. I replaced the O ring with an autozone brand O ring that worked for a few days then the leak happened again. Do you guys know where I can find an O ring for this ? Dealer wont sell just the O ring unfortunately...
Old Jan 6, 2016 | 09:03 AM
try this part is the temp sensor O ring i found for the thermostat housing.
https://www.ecstuning.com/Search/SiteSearch/11518613801/
Old Jan 6, 2016 | 10:13 AM
daonlyillwiz
Ordering this now. Thank you
Old Jan 21, 2016 | 06:54 PM
daonlyillwiz
So I tried that O ring and its still leaking. I give up on this O ring search because i tried like 9 of them and NOTHING WORKED. Im forced to just succumb and replace the thermostat assembly. Im getting the housing and harness for a pretty decent price but now the next question i have is how do i eliminate this metal elbow, is there a replacement hose i need to get ? This is where my sensor is and its's what's currently leaking
Old Jan 22, 2016 | 12:31 PM
nkfry's Avatar
nkfry
It's a terrible design, no O-ring will fix it indefinitely.
We remove the sensor, clean the surfaces, and apply black RTV to it and reinstall.
Never leaks again, not to mention it's a useless sensor once you replace the thermostat, new thermostats have the temp sensor where the bleed screw was, and you're left with a potential leak point from the old sensor.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 22, 2016 | 12:35 PM
Sorry it did not work. The new part for the elbow is 17129802110 for the Automatic trans.
https://www.ecstuning.com/Search/SiteSearch/17129802110/
17129800479 for the manual trans.
https://www.ecstuning.com/Search/SiteSearch/17129800479/
Let me know if you need anything else.
Old Jan 22, 2016 | 12:38 PM
daonlyillwiz
Excellent, that's just what i needed. For some odd reason BMW/Mini couldn't figure out what hose/elbow replacement i needed....i swear the dealerships here on Long Island are a joke :(
Old Jan 24, 2016 | 04:28 PM
cccplus's Avatar
cccplus
I had this problem. Dealer replaced the hoses connecting to the metal elbow and coolant temperature sensor. No more leaks
Old Jan 25, 2016 | 07:58 AM
Welcome.
Old Jan 25, 2016 | 08:11 AM
daonlyillwiz
cccplus unfortunately my leak is coming from the sensor/O-ring and not the hose, i wish it was something simple like a hose leak :(
Old Jan 25, 2016 | 01:25 PM
nkfry's Avatar
nkfry
Cheapest option of repair and only takes about 20 minutes.
Phone:586-792-6464
Old Jan 25, 2016 | 01:31 PM
daonlyillwiz
I thought about that but how/where do you apply the RTV exactly ? in place of the old O ring or further up on the sensor.
I'd love to try that lol
Old Jan 25, 2016 | 01:34 PM
nkfry's Avatar
nkfry
Remove the sensor from the elbow (two tangs you squeeze and it pulls out with a bit of finesse), clean the sensor and elbow of any coolant that may contaminate the seal (spray everything with brake clean), apply a bead of RTV around the existing O-ring and reinstall the sensor. Let the car sit, preferably overnight for a solid seal. Done it on multiple cars with great success.
Phone:586-792-6464
Old Jan 25, 2016 | 01:36 PM
daonlyillwiz
Im gonna give this a shot as a last resort type deal this coming weekend. If it works I owe you a case of beers and i dont even drink lol!!
Ill send a followup to this thread once i do this.
Old Jan 25, 2016 | 01:39 PM
nkfry's Avatar
nkfry
^Well there's your problem!
The RTV fix is far cheaper than buying the whole elbow, and spills far less coolant everywhere when doing the job.
Phone:586-792-6464
You have to have it very clean if you do the RTV thing. Good luck.
Old Jan 25, 2016 | 01:44 PM
daonlyillwiz
yea luckily i have a ton of hoses laying around so ill syphon out whatever coolant is left in the elbow and hopefully i can get it 100% dry
Old Jan 25, 2016 | 01:48 PM
nkfry's Avatar
nkfry
Having a couple pairs of hose pliers would keep coolant loss to a bare minimum, but once the car is off there won't be much coolant that comes out of the hole when you pull the sensor out. It will leak a bit, have a drain pan under the car.
After you have coolant clear of the seal seat just hit everything with brake clean, lay a bead around the o-ring, reinstall, live life. No scare tactics involved with the job.
Phone:586-792-6464
Old Jan 25, 2016 | 01:52 PM
nkfry's Avatar
nkfry
PS, how is the snow treating you guys in Long Island?
Phone:586-792-6464
Old Jan 25, 2016 | 01:55 PM
daonlyillwiz
Haha trust me im a pro at getting this damn sensor off and making sure coolant loss is kept to a minimum, that just shows you how many times i tried fixing this.
Snow here sucks, I had drifts that were almost 3.5 feet deep :(
Old Jan 25, 2016 | 01:58 PM
nkfry's Avatar
nkfry
Hopefully you've got a garage to do the work in, luckily for us it is 36* today and the grass is out. Midwest in late January, gotta love it.
Phone:586-792-6464
Old Jan 25, 2016 | 02:13 PM
daonlyillwiz
So jealous :(
No Garage unfortunately because the M3 and the Ducati occupy that space heh so ill be stuck outside in the cold doing this. Its alright though it should warm up towards the end of the week (mid 40s)
Old Jan 25, 2016 | 02:14 PM
Most people on the east coast are stuck right now, NYC, NJ some. Have you seen some of the MINIs on IG with tons of snow on them. Or buried.
Old Jan 25, 2016 | 02:15 PM
nkfry's Avatar
nkfry
So jealous :(
What use is a garage without badass toys to park in it?!
Phone:586-792-6464
Old Jan 25, 2016 | 09:17 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Moving car to be worked on into the garage would be worth a thought?
