R56 Canbus LED DRL?
Old Jan 1, 2016 | 02:55 AM
R56CPRS's Avatar
R56CPRS
Canbus LED DRL?
Happy 2016 all!
I replaced my stock DRL with canbus LED's - no error, but the light is brighter (more blue) than the Xenon's. Does anyone know what quality canbus led bulbs to get that don't throw an error and match the stock Xenon brightness?
Also: can you program the DRL to ALWAYS be on? So keep light setting on automatic: main lights go on/off depending on outside light conditions, while DRL's are on regardless.
Thanks!
Old Jan 1, 2016 | 11:24 AM
TheBigNewt's Avatar
TheBigNewt
You can program DRLs to come on automatically. The factory LED DRLs are in the form of different fog lights, not part of the Xenon headlights. They look really cool, I'm thinking about retrofitting my 2014 JCW with some. I think they're about $800 installed at the dealership.
Old Jan 2, 2016 | 10:26 AM
siriuszero's Avatar
siriuszero
Thanks!
Yes!
If you have the standard radio:
- Using the BC button on the end of your turn signal stalk, keep pressing it until you see SET/INFO on your instrument cluster display, then press and hold the BC button until the screen changes.
- You should see CHECK-INFO, keep pressing until you see a key with a check mark in front of it, press and hold again to select this.
- These are your personal profile options where you can change settings like; whether you want the lights to blink or not when you lock/unlock the doors, whether you want all the doors to unlock or just the drivers door, etc. Keep pressing until you see what looks like two lights shining away from each other - this is your DRL setting. Switch it to on and your DRLs will stay on all the time, regardless of headlight setting.
If you have MINI Connected, it's much easier:
- Press the home button next to the controller to go to the main menu
- Go to SETTINGS
- Down to LIGHTING
- Select Daytime Running Lights and choose "On"
Old Jan 3, 2016 | 02:58 PM
R56CPRS's Avatar
R56CPRS
Thanks SiriusZero I was aware of this option, however it means your main light are always on. I am interested in running just the lights 'above' the fog lights.
Old Jan 3, 2016 | 03:59 PM
siriuszero's Avatar
siriuszero
Ah sorry....you're right. I forgot that was the default behavior.
You can use NCS Expert to code the headlights off and just have the marker lights be your DRLs, as well as a few other useful things.
Old Jan 4, 2016 | 02:34 PM
R56CPRS's Avatar
R56CPRS
Cheers
Anyone have any suggestions on what canbus led bulbs to use that match the xenon color?
Old Jan 5, 2016 | 12:08 PM
miniuy's Avatar
miniuy
Why no changing your HID to match your DRL LEDs?
What's the stock xenon temp in your car?
Old Jan 5, 2016 | 02:34 PM
daddyandmadi's Avatar
daddyandmadi
Carly app can do your driving lights from your iPhone
Old Jan 6, 2016 | 02:16 AM
R56CPRS's Avatar
R56CPRS
I actually thought of that too, but seems a little ridiculous!
Stock Xenon is 4300K i believe
Old Jan 6, 2016 | 08:41 AM
Originally Posted by siriuszero
Yes!
- Go to SETTINGS
- Down to LIGHTING
+1 great info,.
Old Jan 7, 2016 | 12:36 PM
miniuy's Avatar
miniuy
- Go to SETTINGS
- Down to LIGHTING
It seems it works only on LCI models.
No option on my 2010 base pre-LCI.
Old Jan 7, 2016 | 12:50 PM
miniuy's Avatar
miniuy
No! It is not ridiculous, don´t worry.
You could change your HID bulbs temp for to your favorite colour (white/blue).
Mmm, 4300k is the halogen temp color (yellow).
Are you sure it is 4300k? If yes, it is not easy to find leds matching 4300k (since leds will help you to reach white colour).
I have 6000k on fog light and 7000k on headlights and the T10 LDR matchs with any white led (less "plasma" chinese led, because it is around blue and not white).
I'm using T10 leds like this:
Maybe you are using "plasma" leds like this?:
Old Jan 7, 2016 | 01:01 PM
siriuszero's Avatar
siriuszero
I probably should have added that this option would not appear in countries where DRLs are mandatory, in which case, coding out via NCS Expert is your only option
Old Jan 7, 2016 | 01:35 PM
R56CPRS's Avatar
R56CPRS
I googled it and pretty much everywhere it is stated that stock Xenon's are 4300K
I'll start looking for 5W5 canbus led's @ 4300K
Old Jan 11, 2016 | 12:54 PM
R56CPRS's Avatar
R56CPRS
After endless googling i found these: https://www.superbrightleds.com/more...ofit-car/1127/
Ordered them in natural white which is rated at 4500K - hopefully close enough. Will post pic once installed...
Old Jan 12, 2016 | 04:01 AM
miniuy's Avatar
miniuy
Glad to hear that! I hope it matches as close as you wish.
Let us see the pics when installed to have a good reference.
Old Jan 17, 2016 | 04:50 PM
R56CPRS's Avatar
R56CPRS
Success!
DRL matching Xenon
Old Feb 5, 2016 | 09:34 PM
siwo's Avatar
siwo
Sweet! Those colour match looks great!! I'm planning on getting LED's for the 2012 Countryman that came equipped with stock halogen in reflectors. I don't want to install HIDs where the light output location is wrong and will result in unwanted glares and LEDs are being designed with the light output to be the same location as what the halogen bulbs would come in. Good to know that you are able to find matching coloured bulbs for your fog 'top' part.
mejerry
How to
24
May 23, 2023 06:46 AM
qolor
Dec 31, 2015 07:36 AM
NC TRACKRAT
Dec 29, 2015 06:38 AM
dube53
Dec 28, 2015 11:31 AM
tridaddy
Dec 28, 2015 10:33 AM
