R50/53 Please help! Way motors! Anybody!
Old Dec 12, 2015 | 02:38 PM
Smthkd's Avatar
Smthkd
Ok guy as you know, I have been trying forever to get this stripped harmonic balance off. I have tried just about everything since I couldnt get local help. Just to recap. First I had issues with the center bolt. I finally got this off and began using the pulley puller. Unfortunately two of three bolts stripped. Used a tapping tool and fix one of those hole when the tap broke off into the third hole. Couldnt fix this so I have bought 2 different types of claw pullers. Both are duds and didnt work even after grinding one to grab the H. puller. Next we used a small torch to heat it a little, still no go. Last resort was welding the puller to the friggin thing. That also is a bust. I need a good mechanic willing to cut this sucker of and install my ATI. Im desperate now. I would like to get Way Motors to do it but I need an estimate. I cant just send it without knowing how much Im going to spend. I like the car but I have never had such a difficult time with a "should be simple" job! SOMEBODY HELP PLEASE!
Old Dec 12, 2015 | 04:48 PM
bavmotors's Avatar
bavmotors
Any good shop should be able to get it off without too much of an issue, sucks your still having trouble.
Old Dec 12, 2015 | 05:11 PM
Smthkd's Avatar
Smthkd
Yeah I'm hoping that's the case
Old Dec 12, 2015 | 08:14 PM
Kahnfucious's Avatar
Kahnfucious
Wow you are STILL working on this??? Can't you just drive over to Way or call him and see what he says? I doubt he or any other mechanic will agree to a FINAL price before trying it though given you've mangled a few of the removal points...
Old Dec 12, 2015 | 08:32 PM
Smthkd's Avatar
Smthkd
The car is not drivable. Thus asking for an "estimate " isn't far reaching. It give me an idea of possible cost. It's not a FINAL price.
Old Dec 12, 2015 | 08:51 PM
Kahnfucious
take a few pictures I guess ... I personally would love to understand how welding onto the pulley failed - I mean..mine literally slid off just like in the mod mini video. Not instantly like he shows but once it started - it went pretty quick.
Old Dec 13, 2015 | 03:57 AM
MazMini's Avatar
MazMini
Im still working on mine.. I am just at a lost on how to get it off.. Its a R50 pulley
Old Dec 13, 2015 | 09:03 AM
kaneguy's Avatar
kaneguy
Yea I also surprised that you are still working on this.
From you previous post I got this quote
No I have a bolt extension going down the center of the puller and pulley.
Need to clarify that the bolt I described is a extension bolt that is screwed in to the crankshaft not part the the pulley assembly. The pulley center bolt will push against this extension bolt and not the pulley.
Good luck....
Old Dec 13, 2015 | 10:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like I said before we will do the repair just need to schedule it and bring it in, but there is no way for me to give you a solid quote. This has now been cut on, welded on, stripped and so on so there is no way for me to know how long and what all I'm going to have to do to pull this off. I would budget $400-$500 and hope we can get it done quicker.
Old Dec 14, 2015 | 07:47 PM
dscott90000's Avatar
dscott90000
everything is 4-500 dollars
Old Dec 15, 2015 | 06:24 AM
Kahnfucious
When has anyone had a repair bill that is less than this??? Haha - cars are money pits...all of them. 1 hour of labor is about $100-$150....might seem like a garage would come with big plasma cutters and fancy tools that would zip it right off...sure could do that but there's also flammable fluids, wiring that could get melted, all kinds of things that would need to be considered. I don't have a shop but if I did - those would be my last resorts and I would definitely spend the hour or so first looking for a mechanical solution.
Old Dec 15, 2015 | 07:11 AM
bavmotors's Avatar
bavmotors
Had you taken it to way in the first place he probably could have done this in 3-4 hours, now after it's been hacked up there's no guarantees.
Old Dec 15, 2015 | 12:11 PM
ZippyNH's Avatar
ZippyNH
When I had a shop install the ATI pulley I bought from waymotorworks.... Think it was an hours labour...maybe 1.5...
They used a modified puller to get the old one off...think they said it was a steering wheel puller modded regular pulley puller parts...was done at a MINI centric shop...think it took longer to jack the car up, and take off the wheel, and remove the liner to get at the pulley then the actual time too do it...
Moral of the story...
The longer a bolt has sat in the same spot...untouched, the more likely you should have a pro help...it was tempting to diy it...but for a bit of $$, it was well worth it!!
Old Dec 16, 2015 | 03:59 AM
rt808's Avatar
rt808
Glad mine came-off so easy, replaced the timing chain tensioner as well having issue with code P0300 sounds like running only 2 cylinder.
Old Jan 28, 2016 | 09:24 PM
WayMotorWorks
Vendor
We fought and got the pulley off today. Car is running and driving again, plus we added our WMW 15% pulley kit.
Here is what it looked like when we got it. No threads to use the puller.
Old Jan 28, 2016 | 10:57 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by WayMotorWorks
We fought and got the pulley off today. Car is running and driving again, plus we added our WMW 15% pulley kit. Here is what it looked like when we got it. No threads to use the puller.
Was it rusted to the crankshaft?
Can you elaborate on what you needed to do to finally get it off?
Old Jan 29, 2016 | 05:19 PM
Sprout06's Avatar
Sprout06
Wow! How long did that take!
Old Jan 29, 2016 | 06:24 PM
NItroMidgets's Avatar
NItroMidgets
Holy crap that thing looks beat to hell.
I believe this is one of the times when the decades old saying, "you can get things good, fast and cheap but only two at once" comes to mind. Pick wisely.
Old Jan 30, 2016 | 06:43 AM
Smthkd's Avatar
Smthkd
Thanks WAY! You are AWESOME bro! Sorry I couldnt get there yesterday in time to pick up! I was at work and couldnt get anyone to come in in time to make it to the shop. Im excited! Wish I could get it today!
Old Jan 30, 2016 | 08:24 PM
WayMotorWorks
Vendor
What you see is from the welder when they tried to weld the puller to the pulley.
Old Jan 31, 2016 | 05:46 PM
slo_crx1's Avatar
slo_crx1
When my pulley went on me I read the horror stories about removing them. Still can't believe german engineers decided that pulling the balancer off with those tiny bolts was perfectly acceptable. Even using grade 8 hardware to change mine with the specialty puller, I still managed to break 2 grade 8 bolts. At least the ATI is on and I won't have to worry about that for a long time.
Old Jan 31, 2016 | 06:20 PM
Kahnfucious
Awful lot of slag on there....
Old Jan 31, 2016 | 06:22 PM
Kahnfucious
I'll consider myself one of the lucky ones- my old style crank pulley slid right off...took some cranking on the bolt and what not but it came out...and the new style one went on???
Old Jan 31, 2016 | 08:06 PM
AoxoMoxoA's Avatar
AoxoMoxoA
I assume that at WMW, you are using more or less the same crankshaft pulley removal tool that most folks on this forum would use. Of the pulleys you've replaced, what is the percentage that give you difficulty, as in broken 6mm bolts, or a pulley that just won't budge?
Jb16
Jun 1, 2016 06:31 AM
embiggenedmini
Nov 18, 2015 12:34 PM
Nick Webb
R55 :: Clubman Talk (2008+)
Nov 16, 2015 11:32 AM
Rune
Nov 14, 2015 10:42 AM
InDaClubMan
Nov 14, 2015 02:53 AM
