R50/53 Coolant expansion tank replacement
Old Dec 2, 2015 | 07:21 PM
JPMontes3's Avatar
JPMontes3
Hey y'all,
Quick question. In a bit of a pickle, I need to replace my tank and I was wondering if I need to flush the whole coolant out of the engine or if i can just replace the lost fluid assuming it's all a 50/50 mixture.
Thanks!
Old Dec 2, 2015 | 08:41 PM
gpwpat's Avatar
gpwpat
Just suck out as much coolant as you can using a turkey baster. Then replace tank. Put coolant back in, top off. You will be fine.
Old Dec 2, 2015 | 09:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
just replace what you loose with 50/50 mix. You just need to change the coolant every 4yrs.
Old Dec 3, 2015 | 10:05 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
When's the last time you did a coolant change? If you haven't done it, now might be a good time to do it. In general, it's recommended that you flush and clean out your cooling system once every 36 months, or approximately every three years. We go over this and a lot of information about the cooling system in our coolant change DIY. Otherwise, as the others stated, be sure to top it off and use MINI recommended coolant 82-14-0-031-133 50/50 with distilled water.
888.280.7799 | 6am - 5pm PST
piotrus22
Dec 4, 2015 10:31 AM
odieman23
Dec 3, 2015 07:38 PM
banyan
Dec 1, 2015 04:00 PM
ti22fjc
Nov 30, 2015 03:55 PM
