R56 Tune up filter/plug numbers
Old Nov 17, 2015 | 08:14 AM
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
I am going to give my mini a tune up and i need to know the correct air filter and spark plug(whats the best brand)numbers, also anything else i should replace on her.
Old Nov 17, 2015 | 08:52 AM
What year and model , think you had an R56 S ?
Old Nov 17, 2015 | 08:55 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you are thinking of doing the coils as well, look into our ignition kits HERE. (Plugs are Bosch which are OE and Coils are Genuine). Otherwise if you just want plugs, you can go with the spark plugs we offer HERE. Mahle or Genuine air filter HERE. Check the cabin air filter and see how that looks. Whens the last time you did the fuel filter or any other fluid changes?
888.280.7799 | 6am - 5pm PST
Old Nov 17, 2015 | 10:05 AM
BadgeFTW's Avatar
BadgeFTW
yes i have an R56 S
BadgeFTW's Avatar
BadgeFTW
Thanks, i have only been changing the oil, nothing else.
Old Nov 17, 2015 | 10:17 AM
PelicanParts.com
Vendor
I'd then maybe suggest doing your transmission fluid, brake fluid, and do a coolant flush. One often neglected task on many cars is the maintenance of the cooling system. (If this hasn't been done already) Also, maybe the fuel filter as preventive maintenance. Inspect your drive belts for wear. The belts should be free from cracks, fraying, glazing and missing chunks. Replace belts if any of the previously mentioned issues are present or every four years.
Old Nov 17, 2015 | 10:27 AM
yes i have an R56 S
What year?
Old Nov 17, 2015 | 10:47 AM
BadgeFTW's Avatar
BadgeFTW
What year?
sorry, she is an 08
Old Nov 17, 2015 | 11:07 AM
Great, thanks
You will need Plugs , stock are NGK, but you can do bosch also.
https://www.ecstuning.com/Mini-2008-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Ignition/
You will also need the special spark plug tool socket, we have it here:
14mm Deep Well Spark Plug Socket
https://www.ecstuning.com/Search/SiteSearch/ES2561145/
You will need a ratchet extension in 3/8 drive for that socket also.
For the filter: 13717568728 Mahle and Mann are the same as Genuine, most of the time the same manufacture.
https://www.ecstuning.com/Search/SiteSearch/13717568728/
Check you cabin filter: 64319127516 prefer the carbon one myself.
https://www.northamericanmotoring.co...er-filter.html
Dependent on miles: Fuel Filter
Here is a fuel filter DIY .
The fuel filter sets on the rear right hand side of the tank.
Fuel Filter Kit part number 11252754870
http://www.ecstuning.com/Search/SiteSearch/11252754870/ES21420/
#2 in the diagram.
Here is an install from a MINI Italian site. You can use Google translate, but has great pictures and how to.
Click Here
Also have you had the intake side carbon blasted ? Also if its never been done and you have higher miles.
https://www.northamericanmotoring.co...-cleaning.html
Old Nov 17, 2015 | 11:41 AM
BadgeFTW's Avatar
BadgeFTW
Great, thanks You will need Plugs , stock are NGK, but you can do bosch also. https://www.ecstuning.com/Mini-2008-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Ignition/ You will also need the special spark plug tool socket, we have it here: 14mm Deep Well Spark Plug Socket https://www.ecstuning.com/Search/SiteSearch/ES2561145/ You will need a ratchet extension in 3/8 drive for that socket also. For the filter: 13717568728 Mahle and Mann are the same as Genuine, most of the time the same manufacture. https://www.ecstuning.com/Search/SiteSearch/13717568728/ Check you cabin filter: 64319127516 prefer the carbon one myself. https://www.northamericanmotoring.co...er-filter.html Dependent on miles: Fuel Filter Here is a fuel filter DIY . The fuel filter sets on the rear right hand side of the tank. Fuel Filter Kit part number 11252754870 http://www.ecstuning.com/Search/SiteSearch/11252754870/ES21420/ #2 in the diagram. Here is an install from a MINI Italian site. You can use Google translate, but has great pictures and how to. Click Here Thanks Also have you had the intake side carbon blasted ? Also if its never been done and you have higher miles. https://www.northamericanmotoring.co...-cleaning.html Thanks
Thanks much for the help. I plan on taking her to a local shop for the spark plugs(I probably could do it myself, but i dont want to damage anything) and i will do the cabin filter and air filter myself. Where is the cabin filter? I wont be doing the fuel filter either, i am not much of a mantinace guy. I have not had the intake blasted, how much is it? Cheers Badge from SC
Old Nov 17, 2015 | 11:45 AM
BadgeFTW's Avatar
BadgeFTW
thanks pelican, ill be doing the trans and brake fluid. Just did a coolant flush. The belts look good and the fuel filter will be the mechanics problom
Old Nov 17, 2015 | 11:50 AM
PelicanParts.com
Vendor
You're very welcome. The cabin air filter is in front of the glovebox underneath the right side of the dashboard. We have a DIY for it to help you. Also have a article with information on carbon clean up if you want to review it as well. I've seen shops quote anywhere from $300 to $900.
Old Nov 17, 2015 | 12:02 PM
Linked above. Its a 5 min change on the cabin filter.
Old Nov 17, 2015 | 12:54 PM
BadgeFTW's Avatar
BadgeFTW
Thanks much Pelican and ECS, ill be doing my tune up in a bit thanks to you
Old Nov 17, 2015 | 12:59 PM
You are welcome. I can help you with anything as I work on both my MINIs
JamesDeBart
Apr 16, 2016 05:00 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
vulkandino
Oct 31, 2015 08:29 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
