R56 2013 JCW back-up light question
Old Nov 13, 2015 | 06:37 PM
Raptor911's Avatar
Raptor911
I just purchased a 2013 JCW and I have a back-up light question. I just notice that my left light is solid red and my right light is red on the outer portion but clear in the center. It looks like the pic below. Why the mis-match in lense type? Is this normal? Also when I go into reverse, only the right side lights up and the left side does not. I assume my left bulb needs to to be replaced? Again just seems odd that the left and right side is different.
Old Nov 13, 2015 | 06:51 PM
MarioKart's Avatar
MarioKart
Vendor
It's normal for JCW and GP models. Many of us added the euro left side and wired it to the right.
mQubed Motorsport, Manic Tuning Dealer
Old Nov 13, 2015 | 07:11 PM
Raptor911's Avatar
Raptor911
Thank you for the prompt response. I did some googling (is this a word?) and I discovered this is normal. Super weird on Mini/BMW
Old Nov 13, 2015 | 07:42 PM
MarioKart's Avatar
MarioKart
Vendor
No problem. Is very Mini Quirky.
My GP with tinted lenses and LEF bright bulbs
Old Nov 14, 2015 | 01:56 AM
rkw's Avatar
rkw
The all-red light on the left side is a rear fog lamp. It will only operate if your car has the rear fog option. If your car doesn't have the rear fog option, it does nothing.
Old Nov 14, 2015 | 08:43 AM
timski's Avatar
timski
Yep. It's normal. When I saw this on my JCW I thought "great what did the owner before me do. Now I have to change a lens and a bulb."
Nope. It normal. One side is a fog lamp and this light comes on when you shift the car into reverse I believe. No worries.
Old Nov 14, 2015 | 11:56 AM
rkw's Avatar
rkw
No, the rear fog does not turn on with the car in reverse.
If you don't care about having a rear fog, you can convert it to a second reverse light.
See this thread: https://www.northamericanmotoring.co...-up-light.html
Old Nov 14, 2015 | 12:48 PM
timski's Avatar
timski
Originally Posted by rkw
No, the rear fog does not turn on with the car in reverse. If you don't care about having a rear fog, you can convert it to a second reverse light. See this thread: https://www.northamericanmotoring.co...-up-light.html
What I'm saying is that I agree with the op and can be seen in his pic. The passenger side fog light is clear/white and the drivers side is red. Well I believe (not near my car so I cannot confirm) that the light behind the clear lens (passenger side) only lights up when I put my JCW in reverse. It appears the bulb is bad when you flip on the fog light but it isn't true because that light is only used for the reverse light. The drivers side is red and comes on when you flip on the rear fog light. Correct me if I am wrong. So when you flip on the rear fog light only the drivers side rear light illuminates. And the passenger side doesn't which makes it appear that the passenger side bulb is burnt out. It isn't cuz it's only used as the reverse light. I verified this by swapping bulbs from drivers to passenger side.
Old Nov 14, 2015 | 05:38 PM
rkw's Avatar
rkw
@timski, we are not disagreeing on anything. The OP's car is set up with one reverse light on the passenger side and one rear fog light on the drivers side.
The drivers side rear fog may or may not actually work, depending on whether the car was built with the rear fog option (an extra cost option). If the car doesn't have the option, the rear fog toggle switch will be missing, and although the lamp is there it won't do anything.
If the OP prefers to have two reverse lights (instead of one reverse and one fog), it is possible as described in the link I gave.
Old Nov 14, 2015 | 06:11 PM
timski's Avatar
timski
@timski, we are not disagreeing on anything. The OP's car is set up with one reverse light on the passenger side and one rear fog light on the drivers side. The drivers side rear fog may or may not actually work, depending on whether the car was built with the rear fog option (an extra cost option). If the car doesn't have the option, the rear fog toggle switch will be missing, and although the lamp is there it won't do anything. If the OP prefers to have two reverse lights (instead of one reverse and one fog), it is possible as described in the link I gave.
Ok got it. I re-read all the posts. I didn't realize he didn't have the rear fog option.
midnightblackjcw
Nov 8, 2015 06:06 AM
midnightblackjcw
Oct 27, 2015 10:26 AM
mbatech
Oct 10, 2015 07:21 AM
midnightblackjcw
Oct 8, 2015 11:19 AM
little egg
Oct 1, 2015 12:26 PM
