R56 Water/Meth Install Help.
Old Nov 13, 2015 | 06:40 AM
Maniccs's Avatar
Maniccs
Hello, I am soon going to purchase a water/meth kit for my car and I have looked around but not found how to install it on my R56. Any help would be appreciated. (I have the N18)
Old Nov 14, 2015 | 02:46 PM
oldbrokenwind's Avatar
oldbrokenwind
Howerton HFS4 is, in my opinion, the best WMI system out there for the R56! Fully adjustable for any conditions you want to run. Good instructions and customer service is fantastic. Just don't even think about using poor quality methanol. I've been running a 50 - 50 mix for about 3 years, trouble-free!
Old Nov 15, 2015 | 05:05 AM
cerenkov's Avatar
cerenkov
I also have the HFS4 system from Aquamist/Howerton. If purchased from Howerton then the kit is customized to the MINI. Great system, comes with detailed instructions. It is more expensive than other systems, it all depends on what you want. Other kits are more generic, such as Devil's Own, but they will do the job and are fairly straight forward to install.
There are plenty of people here running meth with all the different kits, if you run into any issues just ask.
Old Nov 16, 2015 | 04:27 PM
tylewis's Avatar
tylewis
Do I have to "program" or input anything when I get mine or is the rate at which the pump operates a set rate? That question make sense?
Old Nov 17, 2015 | 02:37 AM
cerenkov's Avatar
cerenkov
Depends on which kit you buy. For the HFS4, there are a lot of settings but the factory defaults work for 99% of all people, so you really don't need to mess with them. If you choose to utilize the failsafes then you will have to set up the permit window, which can be confusing at first.
Most pumps are progressive. For the HFS4, this is referenced to injector duty cycle and manifold pressure. Other kits it is usually only manifold pressure.
Old Nov 17, 2015 | 02:59 AM
scubbysnacks's Avatar
scubbysnacks
Also are you planning on installing the tank and pump in the back or are you going to use the windshield washer container so you don't lose already limited space in the back.
Old Nov 17, 2015 | 05:25 AM
stevie01's Avatar
stevie01
my post throttle housing adpt two postions available
Old Nov 22, 2015 | 04:31 AM
stevie01's Avatar
stevie01
sec postion for injector
Old Feb 10, 2016 | 01:27 AM
cerenkov's Avatar
cerenkov
Photo of where to mount the FAV for the HFS4
Old Apr 1, 2016 | 06:18 AM
Alanberto's Avatar
Alanberto
Would these also work for the 2011 mini countryman s? It has the n18. Would it be the same if i order it as far as the instructions as the r56?
Old Apr 1, 2016 | 08:36 AM
cerenkov's Avatar
cerenkov
Yes it will work. The instructions are going to be similar enough that you should be able to figure it out. The engine bays are slightly different so the routing of wires and tubing may vary.
Old Apr 1, 2016 | 08:49 AM
Alanberto's Avatar
Alanberto
Ok thank you. Where would be the best place to order the kit from? And what does does it usually cost?
Old Apr 1, 2016 | 11:16 AM
oldbrokenwind
Here's a link to his website --- http://howertonengineering.com
All the info you need is there. Pricing will vary with the options you choose.
Here's another link to a forum with more good info --- http://www.aquamist.co.uk/forum2/vbulletin/
Stefuhneex33
Jan 4, 2016 02:38 AM
KevinR
Nov 15, 2015 08:10 PM
Smthkd
24
Oct 29, 2015 10:04 PM
W-SMini
Oct 22, 2015 02:30 PM
MiniSquirty
Oct 21, 2015 08:05 AM
