R56 MPG Probloms
Old Nov 3, 2015 | 10:47 AM
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
MPG Probloms
I Have an 08 R56 and i normally get about 29-34 mpg and i am now getting 24-27. I had this problom a few months ago but it fixed itself. What could this be, i think it may be the o2 sensor but i am not sure.
Cheers, Badge from SC
Old Nov 3, 2015 | 11:48 AM
O2 sensor would be my first check , after a while you will get a CEL if the 2 sensor fails.
Then I would look at carbon build up on the intake. Do you have a Cooper S ?
Old Nov 3, 2015 | 01:48 PM
BadgeFTW's Avatar
BadgeFTW
Yes it is a cooper s, i have been thinking about the carbon build up, i have not cleaned it since i got it.
Old Nov 4, 2015 | 08:14 AM
Carbon Blasting DIY here: 81292208038 81292208032
https://www.northamericanmotoring.co...-cleaning.html
Old Nov 4, 2015 | 08:52 AM
BadgeFTW's Avatar
BadgeFTW
Carbon Blasting DIY here: 81292208038 81292208032 https://www.northamericanmotoring.co...-cleaning.html
thanks M8
Old Nov 4, 2015 | 08:55 AM
Welcome.
Old Nov 4, 2015 | 09:02 AM
nkfry's Avatar
nkfry
O2 sensor would be far from the first check done.
When were the plugs changed last?
Carbon build up is a slight possibility.
Is the cooling system in tip top order? A coolant leak, or faulty thermostat electronics can hurt mileage.
Air filter quality?
A VANOS solenoid full of sludge can affect the function of the variable timing advance and cause power and mileage drops.
How does the alignment look? Poor alignment can cause poor mileage.
These are all things I would look at before installing a $290 Lambda sensor, especially since they aren't very failure prone in these cars.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 4, 2015 | 10:04 AM
Slave to Felines's Avatar
Slave to Felines
Check your tire pressures. Low pressure will cause more drag. Changing tires, e.g. from summer tires to winter tires, can change the rolling resistance as well. I don't remember which tends to have more and which less, though.
What about ambient temperatures? They've started dropping where I live, and lower temps hurt your fuel economy in something like a dozen small ways.
Alignment can also cause drag, plugs and carbon build-up can affect engine operation.
Lots of stuff to test before you start throwing parts at the problem.
Old Nov 4, 2015 | 01:51 PM
BadgeFTW's Avatar
BadgeFTW
i should probably check the spark plugs and i didn't know a coolant leak could hurt mpg, because i have one. air filter is almost never changed, i always forget to. thanks for the help. ill be doing a water pump change in a little, it should fix the leak. the spark plugs have not been changed science i bought the car at 56,000 miles now it has 98,000. i do not know if the previous owner changed them.
Old Nov 4, 2015 | 02:01 PM
Plugs and air filter are the first to check but when it was fine before and drops off quick its the O2 sensor or some bad carbon build up at some point.
If you need anything else let me know.
Here is the DIY for the water pump and the thermostat with the parts linked.
Doing them both at the same time will get two problems done at once.
https://www.northamericanmotoring.co...hermostat.html
And
https://www.northamericanmotoring.co...rmostat-6.html
Also a great link here: Thermostat , waterpipe , and waterpump DIY.
https://www.northamericanmotoring.co...8-no-heat.html
Waterpump: 11518604888
http://www.ecstuning.com/Search/SiteSearch/11518604888/
Thermostat: 11537534521 KT
http://www.ecstuning.com/Search/SiteSearch/11537534521KT3/
Waterpipe: 11537589713
http://www.ecstuning.com/Search/SiteSearch/11537589713/
Waterpipe Clip : 11537548652
http://www.ecstuning.com/Search/SiteSearch/11537548652/
Old Nov 4, 2015 | 02:02 PM
nkfry's Avatar
nkfry
Just in the maintenance work you listed I can see a loss in MPG.
The thermostat is constantly fluctuating to stay thermally efficient, and provide the best MPG, any discrepancy in coolant temp can affect MPG due to changing fuel tables, timing tables, etc.
MINI states plugs are "due" every 36k in the JCW package cars.
Phone:586-792-6464
Old Nov 4, 2015 | 03:07 PM
BadgeFTW's Avatar
BadgeFTW
thanks for the help guys, when i get my next paycheck ill be right on it. Cheers
PelicanParts.com
May 17, 2016 08:58 AM
PSU 98
Jan 19, 2016 02:10 PM
Beau B
R60/R61 Stock Problems/Issues
14
Dec 15, 2015 04:56 AM
Boverphoto
Nov 6, 2015 06:45 AM
Nov 1, 2015 12:03 PM
