Intermittent misfire codes, no CEL
Old Oct 26, 2015 | 10:17 AM
Shane Wendel's Avatar
Shane Wendel
Using Dashcommand I see misfire codes P0301 and P0304. I can run along the highway triggering the code reads randomly, sometimes the codes will show up, sometimes they don't. There's no check engine light. Just an occasional, barely perceptible stutter at idle.
I've already replaced the spark plugs, and tried swapping the coil from between cylinders 1 and 2. The code doesn't move.
Fuel pressure appears right (~1100 at idle, about ~1700 @ 2200 RPM), so I don't think it's the HPFP.
Any other ideas?
I'm certified pre-owned so I will take it in, but I like to be educated first.
Old Oct 26, 2015 | 12:02 PM
sub3622's Avatar
sub3622
Carbon build up maybe?
I am still fighting the same misfires on cylinders 1 and 2. Next is cleaning the intake valves.
Hope your dealer can fix it and please don´t forget to report back what they find.
Old Oct 28, 2015 | 10:20 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0301 here and P0304 here. Under the causes should give you some ideas. Let us know what they say.
888.280.7799 | 6am - 5pm PST
Old Oct 28, 2015 | 10:42 AM
Shane Wendel
I've decided it wait it out a bit. I'm not even sure if its not just a problem with the cheapo OBD2 module I have. From everything I've read, pending codes should either become stored codes and throw a CEL or delete themselves after a certain number of drive cycles. They shouldn't be appearing/disappearing in the same drive cycle multiple times.
I'm wondering if my OBD2 module isn't really clearing the codes. The car is behaving fine, so now that I've changed the plugs and gotten a fresh tank of fuel from a different station, I'm just going to wait a bit and see what happens.
Old Oct 28, 2015 | 10:48 AM
PelicanParts.com
Vendor
If it's still under warranty it still might not be a bad idea to drop it off and see what they say. That way you know for certain there were no real issues.
Old Nov 11, 2015 | 12:08 PM
Shane Wendel
Just an update...
I burned through two tanks of gas since the initial codes and change plugs as mentioned in the first post and the codes eventually stopped coming up. Not sure which of those was the fix, but it's obvious that my cheap ELM27 code reader and DashCommand weren't actually clearing the pending codes, so they had to fall off naturally.
Old Nov 11, 2015 | 01:14 PM
sub3622's Avatar
sub3622
Great you finally solved the issue
chowpott
Oct 19, 2015 08:37 AM
miniaway
Oct 16, 2015 01:03 PM
Bhouston13
Oct 7, 2015 09:44 AM
navybsn
Oct 4, 2015 03:27 PM
ludrof11
Sep 27, 2015 01:46 PM
