F55/F56 Installing Dash Cam - Electrical Question
Old Oct 19, 2015 | 11:43 PM
MiniSquirty's Avatar
MiniSquirty
I've purchased a dash cam and it came with an electrical hookup. Unfortunately, I have no idea where to install it or even how. Was hoping someone could help me with it. I've attached a picture of the hookup. Is there anyway to hook this up to the fuse box? If so, how would one go about doing that. Again, I've never done this before so detailed instructions would be much appreciated.
Thanks in advance!
Attached Thumbnails Installing Dash Cam - Electrical Question-img_20151019_233804.jpg
Old Oct 20, 2015 | 06:33 AM
Southern Marylander's Avatar
Southern Marylander
Thanks in advance!
I'm also interested in how people have hooked up dash cams. If I can butt into this thread a bit, too, I'm interested in any setups showing the most unobtrusive dash cam setup people have (with pictures). I want a dash cam, but I don't want any huge boxes or wires running around my dashboard.
Old Oct 20, 2015 | 11:10 AM
Capt_bj's Avatar
Capt_bj
this is sometimes called an "add a circuit" and should run less than $10 at any decent auto part store
it is an easy way to add a low power item to your fuse panel; your device would appear to qualify ... your red wire (hot) connects here. The black wire goes to a ground ... all you really need is a metal screw that goes into metal .... look around near the fuse panel ... they are there ... loosen and attach the ground wire.
done
Old Oct 20, 2015 | 11:35 AM
cerenkov's Avatar
cerenkov
There should be a +12 volt power source by the rear view mirror. You should be able to tap into this power. This is similar to what people do for installed radar detectors.
Old Oct 20, 2015 | 03:30 PM
GregoryK's Avatar
GregoryK
Exactly. Some did a PDF on how to do that do a search.
Old Oct 21, 2015 | 07:53 AM
MiniSquirty
I did a search bit i couldnt find it. Do you have a link by chance? Tapping the rear view would be ideal.
Old Oct 21, 2015 | 08:05 AM
GregoryK's Avatar
GregoryK
https://www.northamericanmotoring.co...n-the-f56.html
There is other stuff to - Search "wiring" and pick the relevant posts.
Good luck!
whrisk
Oct 31, 2015 08:54 AM
MiteyF
Oct 19, 2015 01:31 PM
MiteyF
Oct 18, 2015 09:28 AM
schwac2
Oct 17, 2015 06:32 AM
astroBlackMetallic_Mini
Oct 14, 2015 02:12 PM
