F55/F56 Garmin Mini GPS, Click and Drive, and BC 30
Old Oct 19, 2015 | 03:17 PM
HogWldFLTR's Avatar
HogWldFLTR
Likely I'm the only one who's using the GPS Click and Drive system combination. I noticed that the unit allows the use of a blue tooth connected back-up camera. Anyone have any experience with using the BC 30 back-up camera with the unit if you've got one?
Old Oct 20, 2015 | 11:46 AM
HogWldFLTR's Avatar
HogWldFLTR
OK, I'll try a different approach; the BC 30 instructions recommends using the back up lights as the unit's power supply because it will activate the camera when backing up. Will tying into the electrical system cause a problem for the Mini's electronics and cause some sort of fault?
Old Oct 20, 2015 | 03:02 PM
hammerhands's Avatar
hammerhands
Do you have LED bulbs?
Old Oct 21, 2015 | 09:25 PM
HogWldFLTR's Avatar
HogWldFLTR
No; does it make a difference?
Old Oct 22, 2015 | 12:00 AM
hammerhands
Yes, the car seems to monitor the amperage being used by the bulb.
You may need to get into programming with ESYS.
I suspect you can find the backup camera wiring in the rear door handle. If you look under there you will see what looks like a punch-out for the backup camera, even though the part number for the handle with the backup camera has a different number.
Old Oct 22, 2015 | 11:09 AM
HogWldFLTR's Avatar
HogWldFLTR
Thanks; I'll discuss with the dealership installation.
Old Nov 18, 2015 | 12:53 AM
shih's Avatar
shih
Do a DIY
I just had the BC30 installed on my wife's car. It is very easy and do not throw out errors.
Easy DIY as soon as you open the light assembly.
Old Nov 18, 2015 | 07:45 AM
vetsvette's Avatar
vetsvette
Moderator
Do you have a part number for the BC30?
Old Nov 18, 2015 | 08:27 AM
CooperB's Avatar
CooperB
010-12242-10 (BC 30 Wireless Backup Camera)
12AMF56
Nov 22, 2015 06:41 PM
myskylab
Oct 31, 2015 07:28 PM
whrisk
Oct 31, 2015 08:54 AM
rphox2003
Oct 20, 2015 02:35 PM
mremg
Oct 20, 2015 10:31 AM
