R50/53 Oxygen sensor plug
Old Oct 18, 2015 | 11:15 AM
CRC's Avatar
CRC
Oxygen sensor plug
Has anyone had any trouble disconnecting the front O2 sensor plug (between the valve cover and battery cover)? I can't get mine apart no matter what I try. '06 R50.
Old Oct 19, 2015 | 01:44 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you using a 22mm open wrench to remove it? Otherwise, PEL-4491B here is a removal tool, but the 22mm open wrench should honestly work just fine. Let me know if you're still having an issue. Lots of good info in this NAM thread here.
888.280.7799 | 6am - 5pm PST
Old Oct 19, 2015 | 10:28 PM
CRC's Avatar
CRC
Thanks for the input. I have the removal tool for the actual sensor, but it is the electrical plug in the engine bay that I am having problems with.
Old Oct 20, 2015 | 06:05 AM
Helix13mini's Avatar
Helix13mini
First give it a little lateral twist and slide it off the bracket. That will make it easier to pull apart.
Old Oct 20, 2015 | 07:26 AM
CRC's Avatar
CRC
I'll try that. Thanks.
Old Oct 20, 2015 | 09:22 AM
PelicanParts.com
Vendor
Just a note, with the replacement make sure you don't use a Bosch sensor for the pre-cat as individuals do face an issue with codes being thrown. Recommendation is to make sure to use the NTK O2 sensor for the pre-cat sensor so that you don't have the same issues with codes being thrown. Lots of information on this in this NAM thread here. Good luck and hope you get the sensor disconnected.
Old Oct 20, 2015 | 09:58 AM
CRC's Avatar
CRC
Thanks for the info. I have an NTK 25648 O2 sensor.
Old Oct 20, 2015 | 10:02 AM
PelicanParts.com
Vendor
Very good! You're welcome.
ej
Feb 13, 2016 03:25 PM
JMF1975
Oct 19, 2015 01:22 PM
jonnieh123
Oct 16, 2015 02:55 PM
stangyg123
Oct 16, 2015 02:45 PM
thebombardier
Oct 12, 2015 09:46 AM
