R50/53 Strut/ Mount Recommendations
Old Oct 15, 2015 | 04:15 PM
Minor Threat's Avatar
Minor Threat
It looks like I need to replace my struts and mounts in my '03 Cooper S. I've done a lot of reading on this website and others but haven't found much conclusive evidence. What do you guys suggest for brands? I've seen a lot of positive feedback about Koni's but not sure I want to spend that much. I also looked at Monroe but read some poor reviews. How about Bilstein? Does anyone have experience with them? I don't need anything super high performance, just reliable. What do you guys suggest? What about mounts? Is there much of a difference? I can see the rubber bushings are cracked when I look down from under the hood.
Old Oct 15, 2015 | 08:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
These are the strut mounts we use in our shop when we do repairs
http://www.waymotorworks.com/oem-fro...rut-mount.html
For struts we like the koni FSDs for that the best as they ride great, are reliable, and have lifetime warranty.
http://www.waymotorworks.com/koni-fsd-shocks.html
Had a few use these Bilsteins with good luck
http://www.waymotorworks.com/bilstei...0-r52-r53.html
Old Oct 15, 2015 | 09:01 PM
Fly'n Brick's Avatar
Fly'n Brick
+1 on Way's FSD struts. That's a good price below suggested retail. Also recommend going with OEM bushings (which Way can also provide). There's a recent thread reporting that the bargain basement bushings were not holding up well.
Just a quick question: When was the last time you replaced the serpentine belt?
Old Oct 16, 2015 | 10:10 AM
Minor Threat
I haven't owned the car for very long, so I've never changed it. I was hoping to not have to drop the money for the Koni shocks. For normal every day driving, will I really notice a difference between the Koni's and Bilsteins?
Old Oct 16, 2015 | 10:27 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Lots of good reviews about the Bilstein Touring Class shocks & struts for MINI. A few members describe them to feel about the same or a little bit stiffer than OEM. They're well priced as well (linked above). Definitely change out those mounts here while you have everything apart.
888.280.7799 | 6am - 5pm PST
Old Oct 16, 2015 | 10:56 AM
Minor Threat
One more question, is it customary to change the rear upper bushings when replacing the struts? I won't be able to actually look at them until I have the car apart and I need to have all of the parts ahead of time. Thanks for all the great advice.
Old Oct 16, 2015 | 10:59 AM
PelicanParts.com
Vendor
Yes, I would do it while everything is out and if they haven't been replaced yet.
Old Oct 21, 2015 | 06:00 AM
Here is the front mounts and info. Things also to look for.
31306778833
https://www.northamericanmotoring.co...ing-issue.html
Yes, you can get them here. They can sag and when going over bumps you can get noises from the rear.
Here are some options : 33526754123 or 33526754124
https://www.northamericanmotoring.co...ts-of-toe.html
Old Oct 21, 2015 | 12:02 PM
IQRaceworks's Avatar
IQRaceworks
I went with KONI FSD's, and IE fixed camber strut mounts. They are beefier than the oem units, and weren't much more expensive.
sempaipaul
Oct 26, 2015 05:56 PM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
YO MUDA
Oct 5, 2015 04:14 PM
sempaipaul
Sep 18, 2015 03:05 PM
Sep 4, 2015 01:32 PM
