R56 TPMS issue
Old Oct 14, 2015 | 02:55 PM
uconnhuskiesfans's Avatar
uconnhuskiesfans
TPMS issue
Have an '08. Pressure is good and equal on all tires. I reset the TPMS, the light goes out (after driving a short distance) only to come back on shortly after that. Any ideas or suggestions?
Old Oct 14, 2015 | 03:14 PM
Mini3333's Avatar
Mini3333
On my 2008 MINI Cooper S I had a lot of issues with the tire pressure monitoring. My suggestion: If the tire pressure is correct...ignore it for a day or two and see if it goes away.
Old Oct 14, 2015 | 03:43 PM
Slave to Felines's Avatar
Slave to Felines
Does it indicate one specific tire, or all of them, or different ones each time?
Could be the sender(s) in the tire filler stem(s).
Old Oct 15, 2015 | 06:41 AM
uconnhuskiesfans
Ive been ignoring it for weeks.
Old Oct 15, 2015 | 06:43 AM
uconnhuskiesfans
forgive my ignorance as its my wifes daily driver, not mine. i dont recall it telling me which tire it senses as low. only recalling the two lights (on tach and speedo) indicating an issue. am i forgetting something on how to see which tire it is?
Old Oct 15, 2015 | 07:37 AM
Joeygonz's Avatar
Joeygonz
Bad sensor
I had the same issue once and very first thing I did was to reset it. When the TPM light came back on, using the OBD diagnostics and it threw a code of CC ID 14X (sorry I forgot - 149?). Took it to my tire guy and one of the sensors was malfunction and had to replace it. Luckily I usually carry spares in the car so it turned out to be painless.
Best of luck!
Old Oct 15, 2015 | 11:59 AM
Slave to Felines
On my 2012, a little top-down view of the car comes up in the tach, and an arrow points to the corner of the car that is detected as low. Not sure if a 2008 would do the same, though.
Old Oct 15, 2015 | 12:07 PM
Joeygonz's Avatar
Joeygonz
It does that on the '08s also with an arrow pointed to the wheel/tire that has "issues." First time that I had one was when the temperature dropped to single digits and the car was parked outside all night while visiting a friend.
Old Oct 16, 2015 | 02:51 PM
Kimolaoha's Avatar
Kimolaoha
Yep, this.
They are radio transmitters with a shelf life.
2008 was a long time ago
Might wanna replace em all.
Old Oct 16, 2015 | 03:13 PM
mbwicz's Avatar
mbwicz
I had an intermittent issue on my 08, initially just when it was cold on my winter tires. When I would put on the summer wheels, the warnings would go away. Then it went to the warning full time and was not able to be reset. It turned out that one of the receivers was bad (I took it to the dealer to figure out which one). Each corner of the car has a receiver.
Mike
Old Oct 29, 2015 | 09:38 AM
uconnhuskiesfans
update: Now the TPMS says inactive in the tach and the symbol in the speedo is yellow. Clearly i have one (or more) of the individual tire monitors out most likely a battery issue. My question now is that while others in the thread have said an '08 shows which tire is faulting, i cannot figure out where/how. When i cycle through the check/info it doesnt show specific tires, only tpms in general...
Old Oct 29, 2015 | 11:42 AM
mbwicz's Avatar
mbwicz
That is what my car did, a steady 'inactive' note and yellow light, and it would not allow itself to be reset. I couldn't find a way to figure out what sensor was bad. I had to go to the dealer, and it was one of the receivers on the car (not in the wheel). Not sure if an indy mechanic can give you that info, or if it is dealer only.
Mike
Old Oct 29, 2015 | 12:18 PM
The dealership can read the sensor in the wheels and the receivers in the car. Most of the time its the TPMS senors themselves.
Also there is a split year in 9/2009 for the sensor and receiver in gen 2 MINI. So keep that in mind when replacing them. 36236798726 KT & 36106856227 KT
https://www.northamericanmotoring.co...-shut-oof.html
Old Oct 29, 2015 | 08:33 PM
Joeygonz's Avatar
Joeygonz
The tire center at Costco discovered one of my sensors being at fault. That said, they have a way of testing it and labeled my invoice as a flat tire service at no charge (comes with the purchase of lifetime everything)... and replaced it with a spare that I carry in the glove box just in case something similar to this happens.
Old Oct 30, 2015 | 08:38 AM
uconnhuskiesfans
I considered going over to Costco but since I dont have a spare TPMS and I didnt buy the tires there, I wasnt sure if they would even touch it
Old Oct 30, 2015 | 12:16 PM
Joeygonz's Avatar
Joeygonz
I suggest to take it to the place where you had your tires purchased, mounted and balance. It can be treated as a flat tire repair since most places offer lifetime everything to be competitive.
Best of luck!
Old Nov 4, 2015 | 08:20 AM
uconnhuskiesfans
Best of luck!
1 hour in and out at the tire shop. Driver side rear was dead. They have a scanner that tells them which sensor isnt responding. thanks all
KeziaPurrs
Feb 1, 2018 05:45 AM
GimmeBoost
Oct 18, 2015 04:38 PM
grussell
R55 :: Clubman Talk (2008+)
Oct 9, 2015 12:26 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
rt808
Sep 29, 2015 03:15 PM
