R50/53 Wheels cleaning or new ones?
Old Oct 14, 2015 | 10:41 AM
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
My mini isnt washed very often due to traveling ect. The 2 rear wheels both have so much bake dust baked on to them it wont come off. Looks like rust but i dont think so(No pics at the moment) They are the stock cooper wheels and what can i do to clean them or should i just dump them and get a new set off tirerack? If so what size is nice at stock ride height. Thanks Badge from SC
Old Oct 14, 2015 | 10:44 AM
Saltysalt's Avatar
Saltysalt
depends on the wheels you have, a cheap option is to get some brand (sonax....etc) wheel cleaner, actual wheel cleaner. This is meant to remove brake dust from wheels. works very well. if you have the 17 inch slites, i would go for new wheels, only because when you get a different wheel you can loose like 8lbs per wheel rotating mass, feels likea new car
Old Oct 14, 2015 | 10:56 AM
BadgeFTW's Avatar
BadgeFTW
the braked dust dosnt come off noot even with cleaner and vigorous scrubing.
Old Oct 14, 2015 | 11:04 AM
jonw9's Avatar
jonw9
Well, why get new wheels? All that will happen is that they too will accumulate brake dust due to infrequent washing an neglect.
I say, keep what you got if you intend on doing what you are doing.
Old Oct 14, 2015 | 11:05 AM
RB-MINI's Avatar
RB-MINI
What kind of cleaner did you try? Sonax works by chemically reacting with the iron in the brake dust and breaking it down. Spray on your wheel, let soak and it will go from neon green to dark purple as it reacts. It's the only cleaner I've used so far that actually does what it says and hasn't damaged my wheels. Look for videos on YouTube to see how it works.
New wheels are nice if you're tired of your stock wheels and/or they're S-Lites. If you go with tires too, Tire Rack will mount and balance them for free and you'll just have to bolt them on when you get them.
Old Oct 14, 2015 | 11:23 AM
BadgeFTW's Avatar
BadgeFTW
Originally Posted by RB-MINI
What kind of cleaner did you try? Sonax works by chemically reacting with the iron in the brake dust and breaking it down. Spray on your wheel, let soak and it will go from neon green to dark purple as it reacts. It's the only cleaner I've used so far that actually does what it says and hasn't damaged my wheels. Look for videos on YouTube to see how it works. New wheels are nice if you're tired of your stock wheels and/or they're S-Lites. If you go with tires too, Tire Rack will mount and balance them for free and you'll just have to bolt them on when you get them.
ill try it tanks i am tired of the stock wheels too though. Ill try sonax.
Old Oct 14, 2015 | 11:24 AM
BadgeFTW's Avatar
BadgeFTW
Originally Posted by jonw9
Well, why get new wheels? All that will happen is that they too will accumulate brake dust due to infrequent washing an neglect. I say, keep what you got if you intend on doing what you are doing.
good point.
Old Oct 14, 2015 | 12:27 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Another option is to get them blasted and powder coated if you don't want to spend the money on new wheels.
888.280.7799 | 6am - 5pm PST
Old Oct 14, 2015 | 01:39 PM
BadgeFTW's Avatar
BadgeFTW
meh, kind of bored of my stock wheels.
ronn
23
Sep 5, 2017 10:36 AM
marc0011
Sep 10, 2015 10:04 PM
Ladybug-S
Sep 10, 2015 07:08 PM
Sep 10, 2015 11:55 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
