R56 Typical Oil Leaks
Old Oct 9, 2015 | 03:48 PM
tylewis's Avatar
tylewis
Typical Oil Leaks
I was reading a thread below noting absurd dealer costs associated with oil leak problems. I like to be as proactive as possible and would like to address a problem before it happens as opposed to after. I know the R56's are oil leak prone so my question is:
Where do the most common oil leaks originate from and what parts are responsible?
Old Oct 9, 2015 | 04:51 PM
oldbrokenwind's Avatar
oldbrokenwind
There are at least three that are often written up ---
-valve cover - when replacing, requires extra silicone sealant on curvatures (driver side)
-timing chain tensioner works loose
-turbo oil inlet hose gets brittle and deteriorates
Then there's always workmanship issues when changing oil and oil filter.
There's probably others, but I haven't had them.
Old Oct 9, 2015 | 07:39 PM
Systemlord's Avatar
Systemlord
Don't forget the oil filter housing, it has two coolant and two oil channels going through it, God for bid both start leaking at the same time given its one gasket between the condenser. I had coolant gushing out on the freeway, saw the steam and pulled over quickly!
It could have just as well been oil leaking, the outcome would have been much worse!
Old Oct 9, 2015 | 08:13 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
If it ain't leaking don't fix it. I see no financial benefit to fixing what isn't leaking. Once it starts seeping than you can attack it. My last leaking car was a 98 BMW, dealer wanted $1300 and indy mechanic did it for $500. I could have done it for a lot less if I had the time and tools at the time.
Old Oct 11, 2015 | 01:03 PM
tylewis's Avatar
tylewis
I know what you mean, it sounds silly to change parts that aren't broken. As time passes, my plans are to make this a track car. That will include significant modification and therefore, more prone to things going wrong. I am just trying to be as proactive as possible to keep the car functioning as well as possible.
Old Oct 11, 2015 | 05:00 PM
mbwicz's Avatar
mbwicz
There is a bunch of labor involved when changing the turbo oil lines or the oil filter housing gaskets. If either one of these are leaking, replace both at the same time. Go with an aftermarket turbo oil line, the factory replacements will still leak over time.
Have fun,
Mike
Old Oct 13, 2015 | 10:46 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 HERE is a thread on NAM with an individual that appeared to have both the valve cover and turbo oil inlet hose leak. For the turbo inlet look at post #9 as I go over the added heat shield part that MINI added to the oil line to help protect the o ring from failing. Post #15 goes over the common valve cover leak and links to the updated valve cover from MINI. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Oct 14, 2015 | 03:49 PM
tylewis's Avatar
tylewis
These are very helpful thank you. Since I plan on upgrading my downpipe and exhaust manifold, I might be able to tackle the turbo inlet hose while I am there anyway. It doesn't look too too hard.
Old Oct 14, 2015 | 04:07 PM
PelicanParts.com
Vendor
We have the turbo oil line replacement in our turbocharger replacement DIY here that may be helpful to you when you go to tackle that job.
conky
Apr 6, 2016 08:03 PM
obscurity2
Oct 26, 2015 11:37 PM
IDOXLR8
Sep 24, 2015 05:05 AM
Sep 22, 2015 06:26 AM
rikaro
Sep 21, 2015 06:57 AM
