R50/53 What is this part on the supercharger?
Old Sep 28, 2015 | 04:00 PM
patsum's Avatar
patsum
What is the part on here that has a red ring around it? When I pop that bit off on my own charger I can see straight inside of it. Do I want this hole plugged up? Mine only has a plastic thing over it to cover it. My old one had a bolt in it to seal it off.
Old Sep 28, 2015 | 05:13 PM
Shawnnn's Avatar
Shawnnn
http://www.minicooperspeed.com/how-t...ercharger-oil/
Thats where a vacuum line would go. Not sure why your old one would be blocked off
Old Sep 28, 2015 | 05:42 PM
patsum's Avatar
patsum
Oh no.... the previous owner was a half-wit and ruined half the car tinkering and I'm trying to set it right slowly so this is a learning process for me. Where would the vacuum line go to? Chances are he removed it or plugged it up at the source. No idea why. If I cannot find the vacuum line should I block this one off as well? What effects would this have? Shockingly I had no CEL....
Old Sep 28, 2015 | 06:24 PM
Shawnnn's Avatar
Shawnnn
Im pretty sure that one goes to the valve cover. He probably just blocked it off there too
Old Sep 28, 2015 | 06:26 PM
patsum's Avatar
patsum
Is there any harm in just leaving it be and plugging the supercharger hole up on this one as well?
Old Sep 28, 2015 | 06:31 PM
Shawnnn's Avatar
Shawnnn
No idea. I'm sure they put it there for a reason though. If it was my car I would do it correctly.
Old Sep 29, 2015 | 06:19 PM
patsum's Avatar
patsum
Anyone know what this vacuum line does?
Old Sep 29, 2015 | 11:44 PM
Eric_Rowland's Avatar
Eric_Rowland
It's probably EGR related. Don't have one of those on the M45 Eaton on my old Miata.
Old Sep 30, 2015 | 07:37 AM
Helix13mini's Avatar
Helix13mini
It's crank case ventilation from the valve cover.
Old Sep 30, 2015 | 07:38 AM
Helix13mini
Oh, and put it back to stock!
Old Sep 30, 2015 | 02:04 PM
patsum's Avatar
patsum
Trust me I want to make it stock but he already sealed up the hole on the valve cover. So Now what? I'm not sure what negatives will come from sealing up the s/c hole. The guy has an oil catch can system in place on the car as well...
Any guessing what the cons will be?
Old Sep 30, 2015 | 02:20 PM
Helix13mini
The hole in the VC is actually a check valve that is removable. It's threaded in.
bobbiemartin
Jan 20, 2016 05:28 PM
tr3y003
Oct 22, 2015 10:48 AM
elightbo
Aug 17, 2015 01:50 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
