R50/53 R53 Battery ....
Old Sep 26, 2015 | 04:42 PM
MiniSMan's Avatar
MiniSMan
R53 Battery ....
So typically ..How long does the OEM Battery last in a Mini Cooper S ???
I have a 2006 that still has the original Battery and i checked it today and it still has that green dot in the window indicator that says its fully charged ...
Old Sep 26, 2015 | 05:18 PM
Da_Ghost's Avatar
Da_Ghost
Mine lasted 8 years.
Old Sep 27, 2015 | 04:20 PM
BernieCoop's Avatar
BernieCoop
There is another thread on this topic and the majority seem to be right at 5 years.
Old Sep 27, 2015 | 05:18 PM
Finhead's Avatar
Finhead
Mines still the original and measures out perfectly, it's a 2005 Cooper S
Old Sep 27, 2015 | 05:28 PM
MiniSMan's Avatar
MiniSMan
wow ..ok thats a world record ...
Old Sep 28, 2015 | 05:40 AM
Saltysalt's Avatar
Saltysalt
I replaced in jan of this year, I have an 05
Old Sep 28, 2015 | 06:54 AM
buzzsaw's Avatar
buzzsaw
Replaced the oem battery after 8 years. It still started the MINI but with a tad hesitation on the first start of the day. Replaced it to preclude getting stranded.
Old Sep 29, 2015 | 02:07 PM
zzinglish's Avatar
zzinglish
06 S battery life + related issue
Some newbie info here: got my 06 S 2 mos shy of 2 yrs ago had original battery, 8 yrs old, working but "weak" per shop mech. Installed new H5 year ago May, noting small amount of water in well. Last month during a wet spell both DSC & SES came on. Called mech who said disconnect battery & computer may reset. Emptied out boot to do this & found battery almost submerged in well (attached pics). So my warning lit mini has sat a month or so while I collected info, cleaned up the murky mess, repainted, removed the water retaining rubber plug from the well bottom, added gaskets at all brake lites & lift handle, siliconed rubber door seals that didn't, tested the sunroof drains, located online a 200 amp fuse my mechanic says has no part # & installed, reinstalled battery & sadly found my mechanic wrong about the reset & perplexed about the codes found from crank position sensor to undervoltage to CAN (bus) data error from DMR/DDE (DSC lamp on as long as error present) & ready to remove drivers seat to check harness for corrosion.
Seems I'm running in limp mode, no boost, low power, rough idle, having very little fun because it rained, and there's nothing in the manual about it being strictly an indoor machine.
This began my reading on this issue & there are many wet /sad tales out there with huge repair bills begging the obvious questions of how BMW avoided a recall or any responsibility for damages directly attributable to non sealing cars which excel at keeping water in once they flunked keeping it out.
Attached Thumbnails R53 Battery ....-dscn0882.jpg   R53 Battery ....-dscn0827.jpg   R53 Battery ....-dscn0828.jpg
Old Sep 29, 2015 | 04:56 PM
jamez's Avatar
jamez
I regret to say, I've seen the water collection in my R53 as well. Not submerged, but definitely 1/2 battery deep.
Don't know how it got in there, and hasn't been back (but saw a shallow one once before)
Can't add anything at this time, but just wanted to say I've been there
Old Sep 29, 2015 | 06:38 PM
lizardkitty's Avatar
lizardkitty
I have a 2004 and just had to replace the battery this past weekend when it refused to start. Upside was that for the 1st generation you don't have to register the battery!
stevepsd
35
Dec 6, 2022 03:22 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
lrhyne11
Sep 2, 2015 09:48 AM
jeremy_reyes94
Aug 26, 2015 10:10 AM
jeremy_reyes94
Aug 12, 2015 10:56 AM
