R50/53 A/C quit
Old Sep 25, 2015 | 09:48 AM
Brochacho's Avatar
Brochacho
A/C quit
A/C quit yesterday. Parked, it was working fine, get back in car, hot air only. Noticed compressor does not engage. Checked all the fuses/relay, all good. Bought a can of the freon to throw some in, hoping it'd work. Put the connector on, and the pressure shows good/to the high side.
Anyone have any ideas? It's an '05 R53
Thanks!
Old Sep 25, 2015 | 11:04 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Not sure if this will help, but here is a thread on NAM with some discussion about the compressor. If you need to replace it there is a good DIY at post #20. Another thread of discussion here. All testing fuses/compressor checks out, but they all seem to go ahead and replace it. Maybe someone will have more input for you as well.
888.280.7799 | 6am - 5pm PST
Old Sep 25, 2015 | 04:38 PM
Shawnnn's Avatar
Shawnnn
Could be the ac clutch or coil. Seems to be a pretty common problem.
Easier and cheaper than doing the whole compressor since you dont have to mess with the lines and trying to refill it correctly
Old Sep 25, 2015 | 10:13 PM
David.R53's Avatar
David.R53
I always suggest you start with a proper set of gauges to measure high and low side. $40 at Harbor Freight with their common 20% off coupon. What hi&lo side pressure readings did you get at what outside temperature? It tells a lot. Much better of course with the compressor engaged...
MINI (and BMW) doesn't specify a fill pressure. They give a total fill weight. To fill it properly, You would need to recover what's in there, pull vacuum (vacuum pump $80 at HF) and then fill. Pumping vacuum for an extended time (like overnight) also does a decent job at drying and reactivating the drier material Never a bad thing... If it won't hold vacuum, then you know you have a leak to chase. Same steps if you need to replace the compressor. Recover, new compressor, vacuum, fill...
Old Sep 25, 2015 | 11:16 PM
Brochacho's Avatar
Brochacho
My dad has a set...Will have to get out to his place and check it out. Being that it just went out and worked great when parked, and not when I went out a couple hours later, I'd guess its the coil/clutch.
Old Sep 25, 2015 | 11:19 PM
gpwpat's Avatar
gpwpat
Do some searching. You can buy the a.c. compressor clutch solenoid on eBay. You can replace it without opening the system. $100 in parts and 1 to 2 hours you are back in business.
Old Sep 25, 2015 | 11:33 PM
Brochacho's Avatar
Brochacho
Will do...Watched the video posted a couple posts up. Looks super easy for my skill-set.
Old Sep 29, 2015 | 10:24 AM
pirranah's Avatar
pirranah
Is anything else acting up? I ask because ours suddenly quit working, but along with other random electronics like radio, wipers, turn signals and a few others. I checked fuses, A/C pressure, switches ...etc, ended up being a wet body control module (BC1) behind the passenger kick panel. Dried it up and everything was back to normal. So before you toss parts/money at it, check there.
Jim Ferrell
Oct 6, 2015 08:09 AM
potterstein
Oct 2, 2015 09:30 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
Nicefeet
Sep 27, 2015 11:14 AM
dragonby
Sep 25, 2015 08:10 PM
