R50/53 Rear parcel shelf..... Vent vs. No Vent
Old Sep 22, 2015 | 01:35 PM
silence2-38554's Avatar
silence2-38554
So our '05 R53's rear parcel shelf came with a vent in the middle of it. Unfortunately, this shelf is significantly warped / bowed down in the middle so we found a replacement on craigslist. The replacement we found fits perfectly, however, it is from a non-"S" Cooper so it is a solid piece with no vent.
From what I have read, this vent is primarily to allow S owners to hear a bit more of the exhaust note. Other posts I have found refer to the vent being a deliberate design of the cabin's ventilation system.
Can anyone shed some light on this? If it's really necessary, I can always use a Dremel & cut out the vent hole / transfer the honeycomb vent insert over to the new shelf. However, it's mostly for vanity & to hear the exhaust more, I'll just leave it be.
Thanks!
Old Sep 23, 2015 | 04:40 AM
Saltysalt's Avatar
Saltysalt
that would be interesting if it was for exhaust note, if that's the case I would think it would only be applicable for the JCW. the stock exhaust I could here anything but engine noise.
I would imagine its just for ventilation. or looks
Old Sep 23, 2015 | 11:18 AM
FatherG's Avatar
FatherG
Must be for looks, as you cannot fit a body in the trunk.
Old Sep 23, 2015 | 12:32 PM
Capt_bj's Avatar
Capt_bj
I understood the vent to be necessary on an S because of the battery's location in the floor of the boot .... part of the necessary battery ventilation . . .
Not needed on a 50 as the battery was up front; ditto for the GEN2 cars
Old Sep 23, 2015 | 03:25 PM
Eric_Rowland's Avatar
Eric_Rowland
I wouldn't think you'd want the battery venting to the passenger compartment. IIRC there's a vent tube that connects to the OEM battery. In any case, plenty of gaps between the boot and the parcel shelf.
Old Sep 23, 2015 | 05:09 PM
RB-MINI's Avatar
RB-MINI
This is the reason given on the Outmotoring website overview. Seems like there's an air pressure problem on the non-vented shelfs.
Old Sep 24, 2015 | 05:34 AM
Sound for the exhaust ( Cooper S ). Take out the deck completely and you can here the exhaust more when I removed mine. 51467111559
https://www.northamericanmotoring.co...kage-tray.html
Also possible to vent air from the trunk when closed, vent for battery heat. There are several theories I have head from MINI Product Managers over the years.
wkp1219
Nov 13, 2015 07:52 AM
squawSkiBum
Oct 2, 2015 09:21 AM
silence2-38554
Aug 29, 2015 08:10 AM
Shane Wendel
Aug 21, 2015 01:04 PM
