Help diagnose coolant leak
Old Sep 19, 2015 | 12:51 PM
cjny's Avatar
cjny
My 2010 MCS with 65k miles is losing coolant very slowly. There are no drips on the garage floor and the cooling system easily passes a pressure test. A quick review of this forum suggests the usual suspects are water pump and thermostat housing. Can anyone offer tips on telling where the fluid is going?
Old Sep 20, 2015 | 09:50 AM
AZdsrt's Avatar
AZdsrt
Most likely thermostat housing. From the reading I've done, slow leak that collects on top of the transmission..
Old Sep 21, 2015 | 01:11 PM
+1 Its all here. Been there and done all of this myself. We were the first to mention the pooling effect.
https://www.northamericanmotoring.co...8-no-heat.html
At first you can get a small hairline crack at the bottom of the thermostat that leak a couple drips on to the transmission, ( why u cant find it ) , then after a while it pools and then drips down the back.
Old Sep 21, 2015 | 01:28 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1. Yes, it is common to pool on top of the transmission. Check out the water pump as well and look around the system for any signs of seepage/leaking. I've seen a water pump as early as 50k. There is a good DIY here on NAM for the thermostat and the OP posts some info about mileage for when his thermostat and water pump went. Thermostat here if needed. Let us know what you find.
888.280.7799 | 6am - 5pm PST
shorenetworks
Nov 4, 2019 06:18 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
debitsandcredits
Sep 21, 2015 08:34 AM
mimaal
Sep 4, 2015 09:09 AM
