R56 Oil on valve cover
Old Sep 8, 2015 | 07:01 AM
ShadyCoop's Avatar
ShadyCoop
Oil on valve cover
Hi everyone,
I had oil on the valve cover on my r56 MCSa. The oil seems to be coming from the PCV tube on the right side that connects to the intake. I've read somewhere on here that there is an "o-ring" that seals the tube to the valve cover. When I checked I see no "o-ring" only the plastic clip and slots on the tube. If there is an "o-ring" where does it go? Also, where can I buy one? If this could be the solution than I'd rather try it instead of spending $300 on a new valve cover.
Tyler
Old Sep 8, 2015 | 11:34 AM
ShadyCoop's Avatar
ShadyCoop
Pictures
Originally Posted by ShadyCoop
Hi everyone,
Tyler
Here are some pictures of the valve cover and components that I'm talking about. I wiped most of the oil off, but you can see its getting pretty nasty where the PCV is.
Old Sep 8, 2015 | 11:36 AM
ShadyCoop's Avatar
ShadyCoop
Old Sep 8, 2015 | 11:37 AM
ShadyCoop's Avatar
ShadyCoop
Old Sep 8, 2015 | 12:00 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm not sure about the o ring, but I believe the PCV is built into the valve cover (someone correct me if I'm wrong) and you may need to replace the cover to fix the issue. Here is a thread on NAM with some info. Updated cover 11-12-7-646-555 here.
888.280.7799 | 6am - 5pm PST
Old Sep 8, 2015 | 12:05 PM
ShadyCoop's Avatar
ShadyCoop
Ahh I was afraid of that....thanks for the info! Looks like I should start saving for the cover. You think it'll be alright to drive for a while as long as I keep up with the oil?
Old Sep 8, 2015 | 12:09 PM
PelicanParts.com
Vendor
You're welcome. This leak on the valve cover is more common than not unfortunately. I wouldn't go too long, but do keep an eye on your oil level and the leak until you're able to replace the cover.
Old Sep 8, 2015 | 12:10 PM
Grizld700's Avatar
Grizld700
I can verify there is no O-ring to replace at that connection. It is only the tube and U shaped clip as shown in the pictures.
Old Sep 8, 2015 | 12:17 PM
ShadyCoop's Avatar
ShadyCoop
Thanks, I'm hoping I can round up $300 soon enough. Might have to drive the death-trap-junker 1995 Nissan sentra for a while haha
Old Sep 8, 2015 | 03:39 PM
Martin Brenneke's Avatar
Martin Brenneke
pcv valve
Might it be possible to put an o ring on the tube coming out of the valve cover and then fit the tube and locking device on to make a solid connection? Only a suggestion that might work and save some money.
Old Sep 8, 2015 | 04:50 PM
ShadyCoop's Avatar
ShadyCoop
I was thinking of doing that, I'm sure it wouldn't hurt to try. I'll let you guys know how it goes, I'll probably buy it Thursday.
bobbiemartin
Jan 20, 2016 05:28 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
Lex2008
Aug 16, 2015 08:33 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
