R56 Are my spark plugs good? (I took pictures of them)
Old Sep 6, 2015 | 07:26 PM
eliseo1981's Avatar
eliseo1981
Here are my spark plugs, they look to have some sort of buildup around the curved section right above the needle. Is this normal or is that buildup?
Attached Thumbnails Are my spark plugs good? (I took pictures of them)-wp_20150906_003.jpg   Are my spark plugs good? (I took pictures of them)-wp_20150906_004.jpg
Old Sep 6, 2015 | 08:42 PM
eliseo1981's Avatar
eliseo1981
Ok so I cleaned them using sand paper, gasoline, CLR, break cleaner and a paper rag.
Here are the results. Waiting for the plugs to dry completely before reinstalling them. Perhaps I should invest in a new set as I am not sure if the previous owner ever changed them and I have 84k miles.
Attached Thumbnails Are my spark plugs good? (I took pictures of them)-wp_20150906_006.jpg
Old Sep 8, 2015 | 11:12 AM
3lusive's Avatar
3lusive
You can get a new set of those NGK's from ebay for around $40/set of 4. If it were me I'd just buy new spark plugs, and you already took the old ones out anyways
Old Sep 8, 2015 | 01:30 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Here is some good info about changing plugs. Plugs here if needed.
888.280.7799 | 6am - 5pm PST
Old Sep 8, 2015 | 02:42 PM
tylewis's Avatar
tylewis
Any wires worth getting? I know that the effects of after market wires are limited at best but I didn't know if there was a set worth looking into.
Old Sep 8, 2015 | 03:00 PM
PelicanParts.com
Vendor
Sorry, my post was a little confusing. The R56 is different in that it features individual coil packs on the top of each spark plug. Info about the R56 is at the link towards the bottom. Coils listed here, genuine or OEM supplier is probably the best to stick with.
Old Sep 13, 2015 | 07:04 AM
mini4mo's Avatar
mini4mo
How many miles on the plugs?
I think buying new ones would be better than sanding,etc-.
Old May 10, 2016 | 12:03 AM
neonsteve's Avatar
neonsteve
That "buildup" on the curved part just above the "needle" is normal and is there on new plugs also. It's platinum or iridium just like the needle is. That makes the plugs work and last a long time.
Old May 10, 2016 | 05:19 AM
1004ron's Avatar
1004ron
Those plugs would have been good for many thousand miles more, but seeing as you've got them out, I'd change them.
There's more risk cleaning them the way you did - they would have been good to go back in as they were.
09R56
Nov 16, 2022 10:49 AM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
blackie
Aug 23, 2015 08:44 PM
yashmack
Aug 15, 2015 10:16 AM
