R56 A/C Bracket/Hose Issue
Old Sep 6, 2015 | 05:35 PM
makg's Avatar
makg
The PO of my r56 did not have an AC line bracket in correctly and it caused one of the lines to rub through.
Can someone describe how this bracket should be oriented with the hose? And what are the two tabs with holes in them for?
Also, is there supposed to be a shroud over the coolant hose shown in the last image?
Taken from next to the washer bottle. What are the two tabs for with holes in them?
Is there supposed to be a shroud over this rad hose?
Old Sep 9, 2015 | 01:04 PM
oldbrokenwind's Avatar
oldbrokenwind
Maybe if we knew the year / model you're working with, someone could help. It doesn't look like my '07 S hatchback --- which does not have a shroud over the lower radiator hose. Your AC lines look totally different than mine. And, I'd guess the two tabs with holes are mounting brackets. Have you tried looking at the REALOEM illustrated parts breakdown?
Old Sep 9, 2015 | 01:12 PM
makg's Avatar
makg
It is a 2010 MCS. I will take a look at the exploded diagrams, but sometimes it's difficult to see exactly how it should be in place.
Old Sep 10, 2015 | 11:59 AM
Here is the diagram:
http://www.realoem.com/bmw/enUS/show...diagId=64_1540
W0TM8
Dec 19, 2019 07:50 AM
doug5g
12
Apr 17, 2019 12:44 PM
MORENOJM
Sep 20, 2016 08:13 PM
cub4bearindiana
Jun 30, 2016 06:11 AM
damncajun
Aug 17, 2015 08:25 PM
