R59 Rubber Seal Separating
Old Sep 4, 2015 | 04:15 PM
CaptKen's Avatar
CaptKen
The rear rubber seal on my 2013 R59 has started to separate.
The external rubber which presses against the soft top when it's up seems to be in 3 pieces. The left and right sides are joined at the middle by a third rubber piece that lays on top of them -- with about a 1" gap between the two larger seals. ______------______
The center rubber rubber has started to separate and pull away from the larger side pieces, and aside from being a little ugly, I'm worried about water getting under the soft top.
I've tried using automotive tape underneath, rubber cement on the very narrow overlap, and automotive weatherstripping adhesive. All have failed in a few days.
Anyone have any pro tips? Thanks in advance.
Old Sep 4, 2015 | 04:40 PM
Gil-galad's Avatar
Gil-galad
Pics? Might help us visualize what you're describing.
Old Sep 4, 2015 | 04:42 PM
CaptKen's Avatar
CaptKen
I thought about that right after I went out to take one more stab at it. Assuming the next fix fails, I'll post some pics.
Thanks again for the help.
Old Sep 5, 2015 | 09:17 AM
TG.'s Avatar
TG.
Originally Posted by gil-galad
pics? Might help us visualize what you're describing.
+1
Old Sep 11, 2015 | 01:05 PM
Yes, pics.
Old Sep 12, 2015 | 05:28 AM
dongood's Avatar
dongood
It's a 2013 still under warranty, why not simply take it to the dealer to get fixed properly at no cost to you?
Old Sep 14, 2015 | 10:04 AM
+1 then take it to the dealer and they should cover it.
Old Oct 2, 2015 | 03:53 PM
johnsc's Avatar
johnsc
Thumbs up Rubber seal
I know exactly what you're referring to. Mine is popping up as well. I'd be interested to hear the outcome with the dealer.
Old Oct 2, 2015 | 04:11 PM
TG.'s Avatar
TG.
Personally I have no idea what you guys are talking about . . . . . . pics?
Old Oct 2, 2015 | 07:12 PM
johnsc's Avatar
johnsc
Pic
I think he's talking about this thingy...
Old Oct 2, 2015 | 08:05 PM
TG.'s Avatar
TG.
Ooohh that guy . . . my mind was not on that at all. I was thinking window seal for some reason. Now I see a picture and read the original description, it makes perfect sense! Other than being a little ugly, yes I wouldn't overly worry about this little piece. It is there to finish the loop and to avoid a massive amount of water entering that area. But none of this is really water tight. It's mostly to avoid excessive amount of water during heavy downpour.
If it's under warranty I would have it fixed. But after that I personally probably would fix it myself one way or another... One of which could be to look on how to properly remove it, and then heat it with a heat gun. If that fail, than replace it.
Old Oct 21, 2015 | 06:32 AM
Center rear trim looks like. Have not seen those lift up.
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
Fordgt4
Oct 10, 2015 10:42 AM
Nicefeet
Sep 24, 2015 06:53 PM
Suspension Products
Sep 10, 2015 11:46 AM
